I am actually a newby on adruino. But want to make this stuff working. I read an article about building a table foosball with light barriers for transfering the goals to a website. Now I have the hardware but actually some problems with the code for the adruino one with the sparkfun wifi shield. The barriers are on Pin 2 and 4.
- I tested the uno with the wifi shield examples: working without any problems
- I tested the script I have without using wifi but I actually cant manage to use it with the wifi. I think there are some problems with the new version of the wifly libary?
This ist the code I am using - maybe you can help me on finding the errors?
*** CONFIGURATION ***
#define TABLE_ID "main"
// - INTERNET_WIFLY (Sparkfun WiFly shield), or
// - INTERNET_MOCKUP (simulate connection)
#define INTERNET_WIFLY
// WIFI Access
char WIFLY_SSID[] = "gastknallt";
char WIFLY_PASSPHRASE[] = "berlin2012";
// Server
char SERVER_NAME[] = "82.165.145.84";
byte SERVER_IP[] = {82, 165, 165, 84};
#include "WiFly.h"
// Define to enable output messages on Serial
#define DEBUG_APP
/** CONSTANTS AND GLOBALS **/
// Pin constants
const int GOAL_A_PIN = 2;
const int GOAL_B_PIN = 4;
const int RESET_A_PIN = 3;
const int RESET_B_PIN = 5;
const int LED_PIN = 8; // Standard LED pin 13 used by Spi
// Uniqueness token, initialized by random
#if defined(INTERNET_WIFLY)
// The client for communication with goal server
Client client(SERVER_IP, 80);
#endif
// Whether we think we have associated/connected
boolean associated = false;
boolean connected = false;
int failures = 0;
// Debugging
#ifdef DEBUG_APP
#define LOG(message) Serial.print(message)
#else
#define LOG(message) (((0)))
#endif
*** HELPER FUNCTIONS ***
void disconnect()
client.stop();
#endif
connected = false;
boolean ensureConnection(boolean checkWiFlyStatus)
WiFlyDevice::Status status = checkWiFlyStatus ? wiFly.getStatus(false) : WiFlyDevice::StatusConnected;
if (status == WiFlyDevice::StatusError || status == WiFlyDevice::StatusNotAssociated
|| status == WiFlyDevice::StatusNoIp)
if (associated)
if (status == WiFlyDevice::StatusNotAssociated)
LOG("ERROR: Association LOST, resetting...\n");
else if (status == WiFlyDevice::StatusNoIp)
LOG("ERROR: No WiFi IP, resetting...\n");
LOG("ERROR: WiFi problem, resetting...\n");
reset();
LOG("Joining network...\n");
if (!wiFly.join(WIFLY_SSID, WIFLY_PASSPHRASE))
LOG("ERROR: Joining network failed, trying again later.\n");
flashError(1);
if (failures++ >= 3)
LOG("ERROR: Three failures, resetting.\n");
reset();
return false;
LOG("Network joined.\n");
associated = true;
connected = false;
failures = 0;
if (!client.isConnected() || status != WiFlyDevice::StatusConnected)
if (connected)
LOG("Connection LOST, reconnecting...\n");
LOG("Preconnecting to server...\n");
if (!client.connect(false) || !client.isConnected())
LOG("Connection FAILED, trying again later. (003) \n");
flashError(2);
reset();
return false;
LOG("Connected.\n");
connected = true;
failures = 0;
delay(250);
#endif
return true;
void flashError(int errorNo)
int i;
for (int i=0; i<8; i++)
digitalWrite(LED_PIN, HIGH);
delay(100);
digitalWrite(LED_PIN, LOW);
delay(100);
for (int i=0; i<errorNo; i++)
void reset()
associated = false;
connected = false;
wiFly.begin();
#endif
failures = 0;
*** Setup and main loop ***
LOG("Initializing...\n");
pinMode(GOAL_A_PIN, INPUT);
pinMode(GOAL_B_PIN, INPUT);
pinMode(RESET_A_PIN, OUTPUT);
pinMode(RESET_B_PIN, OUTPUT);
pinMode(LED_PIN, OUTPUT);
digitalWrite(GOAL_A_PIN, LOW);
digitalWrite(GOAL_B_PIN, LOW);
digitalWrite(RESET_A_PIN, LOW);
digitalWrite(RESET_B_PIN, LOW);
for (int i=0; i<10; i++)
delay(50);
delay(50);
randomSeed(analogRead(0));
token = random(65535);
#ifdef INTERNET_WIFLY
wiFly.begin();
while (!ensureConnection(true))
#endif
digitalWrite(RESET_A_PIN, HIGH);
digitalWrite(RESET_B_PIN, HIGH);
delay(10);
delay(10);
LOG("Initialization done.\n");
char string[512];
// Analyze inputs until we find a goal (HIGH is true)
// Also check that we are still connected to the server and access point
int playerPin = GOAL_A_PIN;
long checkCount = 0;
while (true)
playerPin = playerPin == GOAL_A_PIN ? GOAL_B_PIN : GOAL_A_PIN;
if (digitalRead(playerPin) == HIGH)
if ((checkCount % 200) == 0)
while (!ensureConnection(checkCount == 0))
delay(5000);
delay(10);
checkCount = (checkCount + 1) % 2000;
#ifdef DEBUG_APP
sprintf(string, "Goal for %s team, ID %lu\n", playerPin == GOAL_A_PIN ? "home" : "visitors", token);
LOG(string);
#endif
// Retry at most 3 times
boolean success = false;
while (!success && failures < 3)
while (!ensureConnection(false))
// Send a POST to the goal server
char content[128];
sprintf(content, "token=%lu&table=%s", token, TABLE_ID);
sprintf(string, "POST %s/events.php?type=goal&team=%s HTTP/1.1\r\n"
"Host: %s\r\n"
"User-Agent: Arduino/KnalltsKicker\r\n"
"Content-Type: application/x-www-form-urlencoded\r\n"
"Content-Length: %d\r\n\r\n%s",
playerPin == GOAL_A_PIN ? "home" : "visitors", SERVER_NAME,
strlen(content), content);
LOG("Sending request...\n");
LOG(string);
LOG("\n");
#if defined(INTERNET_ETHERNET) || defined(INTERNET_WIFLY)
client.print(string);
#endif
LOG("Request done, checking response...\n");
success = findInEthernetResponse("200 OK", 5000);
#elif defined(INTERNET_WIFLY)
success = wiFly.findInResponse("200 OK", 5000);
#else
success = true;
#endif
if (success)
LOG("Request successful.\n");
failures = 0;
LOG("Request FAILED.\n");
failures++;
disconnect();
token++;
if (!success)
LOG("Giving up and resetting...\n");
reset();
ensureConnection(true);
// Reset goal flip-flop and wait for input to be false (LOW) again
do
digitalWrite(playerPin == GOAL_A_PIN ? RESET_A_PIN : RESET_B_PIN, HIGH);
delay(10);
digitalWrite(playerPin == GOAL_A_PIN ? RESET_A_PIN : RESET_B_PIN, LOW);
delay(10);
while (digitalRead(playerPin) != LOW);
// Disconnect and preconnect again
if (success)
disconnect();
ensureConnection(false);
LOG("Ready for next goal.\n");
ERRORs
sketch_sep21b.cpp: In function 'boolean ensureConnection(boolean)':
sketch_sep21b:78: error: 'Status' is not a member of 'WiFlyDevice'
sketch_sep21b:78: error: expected `;' before 'status'
sketch_sep21b:79: error: 'status' was not declared in this scope
sketch_sep21b:79: error: 'StatusError' is not a member of 'WiFlyDevice'
sketch_sep21b:79: error: 'StatusNotAssociated' is not a member of 'WiFlyDevice'
sketch_sep21b:80: error: 'StatusNoIp' is not a member of 'WiFlyDevice'
sketch_sep21b:84: error: 'StatusNotAssociated' is not a member of 'WiFlyDevice'
sketch_sep21b:86: error: 'StatusNoIp' is not a member of 'WiFlyDevice'
sketch_sep21b:95: error: 'wiFly' was not declared in this scope
sketch_sep21b:115: error: 'status' was not declared in this scope
sketch_sep21b:115: error: 'wiFly' was not declared in this scope
sketch_sep21b:115: error: 'StatusConnected' is not a member of 'WiFlyDevice'
sketch_sep21b:116: error: 'class Client' has no member named 'isConnected'
sketch_sep21b:116: error: 'StatusConnected' is not a member of 'WiFlyDevice'
Thank you so much!!!
