the code of wifi control car didnt work, i use e-gizmo328, wifi shield CC3000 and servo motor. It already connected in the wifi but when requesting an IP address its stock.
Pin CONNECTION
MISO = pin 12
MOSI = ping 11
SCK = pin 13
CS = pin 10
IRQ = pin 3
V-EN = pin 5
THIS IS THE CODE!!
- Simple robot control with Arduino & the CC3000 WiFi chip
// Include required libraries
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
#include <stdlib.h>
String result;
int motorCommand[4];
// Define CC3000 chip pins
#define ADAFRUIT_CC3000_IRQ 3
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
// Motor pins
int speed_motor1 = 8;
int speed_motor2 = 7;
int direction_motor1 = 9;
int direction_motor2 = 6;
const unsigned long
dhcpTimeout = 60L * 1000L, // Max time to wait for address from DHCP
connectTimeout = 15L * 1000L, // Max time to wait for server connection
responseTimeout = 15L * 1000L; // Max time to wait for data from server
uint32_t t;
int resultLength;
// WiFi network (change with your settings !)
#define WLAN_SSID "routernamin" // cannot be longer than 32 characters!
#define WLAN_PASS "maypassword"
#define WLAN_SECURITY WLAN_SEC_WPA2 // This can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
// What TCP port to listen on for connections.
#define LISTEN_PORT 8888
// Create CC3000 instances
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
SPI_CLOCK_DIV2);
// Create server
Adafruit_CC3000_Server robotServer(LISTEN_PORT);
result = "";
for(int i=6;i<=9;i++)
pinMode(i, OUTPUT); //set pin 4,5,6,7 to output mode
/* Initialise the module */
Serial.println(F("\nInitializing..."));
if (!cc3000.begin())
Serial.println(F("Couldn't begin()! Check your wiring?"));
while(1);
if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
Serial.println(F("Failed!"));
while(1);
Serial.println(F("Connected!"));
Serial.println(F("Request DHCP"));
while (!cc3000.checkDHCP())
delay(100); // ToDo: Insert a DHCP timeout!
/* Display the IP address DNS, Gateway, etc. */
while (! displayConnectionDetails()) {
// Start listening for connections
robotServer.begin();
Serial.println(F("Listening for connections..."));
// Try to get a client which is connected.
Adafruit_CC3000_ClientRef client = robotServer.available();
if (client) {
boolean currentLineIsBlank = true;
// Check if there is data available to read.
while (client.available()) {
char c = client.read();
result = result + c;
Serial.write(c);
// Delete HTTP headers
if(result.endsWith("Content-Type: text/html"))
result="";
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(5);
// close the connection:
client.close();
Serial.println("client disconnected");
// Format result and extract the variables
format_result(motorCommand,result);
// Print received values
Serial.println("Motor 1 speed: " + String(motorCommand[0]) + " and direction: " + String(motorCommand[2]));
Serial.println("Motor 2 speed: " + String(motorCommand[1]) + " and direction: " + String(motorCommand[3]));
// Send motor commands
send_motor_command(speed_motor1,direction_motor1,motorCommand[0],motorCommand[2]);
send_motor_command(speed_motor2,direction_motor2,motorCommand[1],motorCommand[3]);
// Reset result variable
result = "";
void send_motor_command(int speed_pin, int direction_pin, int pwm, boolean reverse)
analogWrite(speed_pin,pwm); // Set PWM control, 0 for stop, and 255 for maximum speed
if(reverse)
digitalWrite(direction_pin,HIGH);
digitalWrite(direction_pin,LOW);
void format_result(int* array, String result) {
result.trim();
resultLength = result.length();
Serial.println(result);
int commaPosition;
int i = 0;
do
commaPosition = result.indexOf(',');
if(commaPosition != -1)
Serial.println( result.substring(0,commaPosition));
array = result.substring(0,commaPosition).toInt();
i = i+1;*
result = result.substring(commaPosition+1, result.length());*
else*
if(result.length() > 0) {*
Serial.println(result);*
while(commaPosition >=0); *
@brief Tries to read the IP address and other connection details*
bool displayConnectionDetails(void)
uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;*
if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))*
Serial.println(F("Unable to retrieve the IP Address!\r\n"));*
return false;*
else*
Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);*
Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);*
Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);*
Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);*
Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);*
Serial.println();*
return true;*
HELP ME GUYS PLS!!!!!!!!!!!!!!!!
