Wifi control LED light: Two Clients
Project Goal
I want to have 4 LED Diods in my house: Each one in the kitchen, staircase, livingroom and bedroom.
If I turn on the one in the kitchen via a manual button OR webbrowser, the others should turn on too.
My Idea
Use four ESP32 S2 mini. One acts as a webserver and three others as clients.
The LED diodes are connected to a pin with a resistor.
How it should work
Basically it is just an simple value (on or off) that changes via the web interface or the button. The clients read that.
Progress so far
I found tons of sketches for similar scripts but I cannot manage to get my project to work.
Mostly the sketches don't store the on/off value on the server, but just send an on / off command to the client or it only works on one controller but not all of them.
The sketches need to have these components:
Serverside
  1. Establish a webserver that stores the current state (LED on or off)
  2. Offers a webinterface
  3. Toggles the LED state by pressing a manual button
  4. Toggles the LED state by a virtual button in the webinterface in the browser
Clientside
  1. Requests the LED state every 60 seconds
  2. Turns LED on / off
So far, my server sketch looks like the following.
However I do not know how I can "publish" the current LED state for the clients to request and how to request it on the clientside
int LED_PIN = 4;     // LED Pin
int BUTTON_PIN = 5;  // Button Pin
int ledState = LOW;              // the current state of LED
String ledStateNumeric = "OFF";  // Have a word for the LED status
int lastButtonState;             // the previous state of button
int currentButtonState;          // the current state of button
#include <WiFi.h>
const char* ssid = "#";
const char* password = "#";
WiFiServer server(80);
  delay(10);
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.println("IP address: ");
  server.begin();
  pinMode(LED_PIN, OUTPUT);           // set arduino pin to output mode
  pinMode(BUTTON_PIN, INPUT_PULLUP);  // set arduino pin to input pull-up mode
  currentButtonState = digitalRead(BUTTON_PIN);
  lastButtonState = currentButtonState;          // save the last state
  currentButtonState = digitalRead(BUTTON_PIN);  // read new state
  if (lastButtonState == HIGH && currentButtonState == LOW) {
    Serial.println("The button is pressed");
    ledStateNumeric = "ON";
    // toggle state of LED
    ledState = !ledState;
    // control LED arccoding to the toggled state
    digitalWrite(LED_PIN, ledState);
    WiFiClient client = server.available();  // listen for incoming clients
    if (client) {                     // if you get a client,
      Serial.println("New Client.");  // print a message out the serial port
      String currentLine = "";        // make a String to hold incoming data from the client
      while (client.connected()) {    // loop while the client's connected
        if (client.available()) {     // if there's bytes to read from the client,
          char c = client.read();     // read a byte, then
          Serial.write(c);            // print it out the serial monitor
          if (c == '\n') {            // if the byte is a newline character
            // if the current line is blank, you got two newline characters in a row.
            // that's the end of the client HTTP request, so send a response:
            if (currentLine.length() == 0) {
              // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
              // and a content-type so the client knows what's coming, then a blank line:
              client.println("Content-type:text/html");
              client.println();
              // the content of the HTTP response follows the header:
              // Display the HTML web page
              client.println("<!DOCTYPE html><html>");
              client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
              client.println("<link rel=\"icon\" href=\"data:,\">");
              // CSS to style the on/off buttons
              // Feel free to change the background-color and font-size attributes to fit your preferences
              client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
              client.println(".button { background-color: #4CAF50; border: none; color: white; padding: 16px 40px;");
              client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
              client.println(".button2 {background-color: #555555;}</style></head>");
              // Web Page Heading
              client.println("<body><h1>ESP32 Web Server</h1>");
              // Display current state, and ON/OFF buttons for GPIO 26
              client.println("<p>LED - State " + ledStateNumeric + "</p>");
              // If the output26State is off, it displays the ON button
              if (ledStateNumeric = "OFF") {
                client.println("<p><a href=\"/26/on\"><button class=\"button\">ON</button></a></p>");
                client.println("<p><a href=\"/26/off\"><button class=\"button button2\">OFF</button></a></p>");
              client.println("</body></html>");
              // The HTTP response ends with another blank line:
              client.println();
              // break out of the while loop:
            } else {  // if you got a newline, then clear currentLine:
              currentLine = "";
          } else if (c != '\r') {  // if you got anything else but a carriage return character,
            currentLine += c;      // add it to the end of the currentLine
      // close the connection:
      client.stop();
      Serial.println("Client Disconnected.");
why is waiting/processing a server request contingent on a button press?
if you want to have a button, it's processing should be independent of web processing
and if you want to process multiple clients, i don't believe the web processing code should be inside a loop while (client.connected()) {. if a client becomes available because of a request, service the request and wait for another, possibly from a different client
