Wifi Detection Project
We are having trouble with our code for a project. We are attempting to make a light strip light up by the detection of wifi using the Arduino Mega and WiFly Shield. We have all the right the connections, but we seem to be missing a <PololuLedStrip.h> library. We already had the other libraries, but we don’t know how to add the last one.
We have attached pictures of our coding. Anything helps!!
While I go look for a picture of an answer, you can post your code correctly. Read the stickies at the top of this forum - the ones you were supposed to read BEFORE you posted (so you didn’t look like an idiot).
Have you downloaded the library? From where? To where? What did you do with it after downloading it?
To post code and/or error messages:
  1. Use CTRL-T in the Arduino IDE to autoformat your code.
  2. Paste the autoformatted code between code tags (the </> button)
    so that we can easily see and deal with your code.
  3. Paste the complete error message between code tags (the </> button)
    so that we can easily see and deal with your messages.
Before posting again, you should read the three locked topics at the top of the Programming Questions forum, and any links to which these posts point.
Good Luck!
Did you even TRY Google?
