The idea behind was to design a safe, compact, all-in-one Universal WIFI MAINS (EU/US) compatible 8x High Power Relays board that can be easily used for industrial or home automation projects and experiments, fully compatible with Arduino, ARM, ESP8266, ESP32, PIC, RaspberryPI, etc.
Just take a look at your product. Looks good. However the UI seems to be too simple and a little boring. Another thing is that there is no a feedback signal from the relay. Right? Why don't you add this feature?
bwxd:
Thank you for your feedback.
MPRSx8 Board is designed as a Home Automation Development board with WIFI capabilities that can help you to easy develop related projects.
The software you can see in the related Youtube Video is just a simple driver example not intented to show it as a finished application.
If you use ESPBasic you can make you application interface looking as fancy as you want using CSS.
Also you can integrate it directly with a Home Automation platform as Domoticz or OpenHAB, case when it's own interface become quite irrelevant.
