WiFi does not want to connect (ESP32 on IDE ARDUINO)
#include <EEPROM.h>
#include <WiFi.h>
#include <BluetoothSerial.h>
#define EEPROM_SIZE 512
#define led_verde 5
#define led_verme 4
#define jumper 15
TaskHandle_t pisca_verde;
//TaskHandle_t inter_verde;
TaskHandle_t pisca_verme;
//TaskHandle_t inter_verme;
void pisca_verme_fun( void * parameter ) {
  while(true) {
  digitalWrite(led_verme,HIGH);
  digitalWrite(led_verme,LOW);
void pisca_verde_fun( void * parameter ) {
  while(true) {
  digitalWrite(led_verde,HIGH);
  digitalWrite(led_verde,LOW);
bool write_eeprom(int ini, String text) {
  bool res = false;
  int tam = text.length();
  EEPROM.write(ini,tam);
  if (ini >= 0 && tam < EEPROM_SIZE) {
      for (int i = ini+1 ; i <= ini+tam ; i++) {
        char c = text.charAt(i-1-ini);
        EEPROM.write(i,c);
        res = true;
    return res;
String read_eeprom(int ini) {
  String search;
  if(ini >= 0 && ini < EEPROM_SIZE) {
    int tam = EEPROM.read(ini);
    for (int i = ini+1; i <= ini+tam; i++) {
      int c = EEPROM.read(i);
      search += char(c);
  return search;
bool conecta_wifi_eeprom() {
  Serial.println("USER: "+read_eeprom(0));
  Serial.println("PASS: "+read_eeprom(34));
  int attem = 0;
  String ssid_buff = read_eeprom(0);
  String pass_buff = read_eeprom(34);
  xTaskCreate (
    pisca_verme_fun,
    "pisca_led_verme",
    10000,
    NULL,
    1,
    &pisca_verme
  while(attem < 5 && digitalRead(jumper) != 0) {
    WiFi.disconnect();
    WiFi.begin((const char*)ssid_buff.c_str(),(const char*)pass_buff.c_str());
    Serial.print("Conectando...");
    int t = 0;
    while(WiFi.status() != WL_CONNECTED && t < 75 && digitalRead(jumper) != 0) {
      Serial.print(".");
      t++;
    if(WiFi.status() == WL_CONNECTED) {
      Serial.println("Conectado!");
      return true;
      Serial.println("Erro na conexão! - "+String(WiFi.status())+" - "+String(attem));
      attem = attem+1;
  vTaskDelete(pisca_verme);
  Serial.println("esperando");
  while(digitalRead(jumper) != 0) {}
  ESP.restart();
bool config_bluet_eeprom() {
  BluetoothSerial ESP_BT;
  ESP_BT.begin("AutoHouse - conf.");
  Serial.println("BLE ligado");
  xTaskCreate (
    pisca_verde_fun,
    "pisca_led_verde",
    10000,
    NULL,
    1,
    &pisca_verde
  int buff;
  for(int t = 0; t < 3001; t++) {
    String text = "";
    while(ESP_BT.available()) {
      buff = ESP_BT.read();
      text += char(buff);
      delay(20);
    if (text != "") {
      Serial.println(text); // format: ssid;pass
      ESP_BT.println(text);
      int pos_corte = text.indexOf(";");
      String ssid = text.substring(0,pos_corte);
      String pass = text.substring(pos_corte+1,text.length()-1);
      Serial.println(ssid);
      Serial.println(pass);
      write_eeprom(0,ssid);
      write_eeprom(34,pass);
      EEPROM.commit();
      delay(100);
    delay(20);
  vTaskDelete(pisca_verde);
  while(digitalRead(jumper) == 0) { delay(100); }
  /*digitalWrite(led_verde,LOW);*/
  ESP.restart();
  pinMode(jumper,INPUT_PULLUP);
  pinMode(led_verme,OUTPUT);
  pinMode(led_verde,OUTPUT);
  EEPROM.begin(EEPROM_SIZE);
  if(digitalRead(jumper) == 0) {
    config_bluet_eeprom();
    if(conecta_wifi_eeprom()) {
      Serial.println("Finalmente campeão ... !!! ... !!!");
      while(true) {}
The code above does not connect to the wifi that is stored in eeprom. I will put below what appears in the serial.
USER: *********
PASS: ********
Conectando..............................................................................Erro na conexão! - 6 - 0
Conectando..............................................................................Erro na conexão! - 6 - 1
Conectando..............................................................................Erro na conexão! - 6 - 2
Conectando..............................................................................Erro na conexão! - 6 - 3
Conectando..............................................................................Erro na conexão! - 6 - 4
esperando
Note: The password and login are apparently correct.
If anyone has an idea of ​​what it can be, it will help a lot.
