WiFi Error with Client Object
I get an error which has me baffled.
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClient.h>
#include <ESP8266WiFiMulti.h>
ESP8266WiFiMulti WiFiMulti;
const char* ssid = "Cabin-Sensor-Access-Point";
const char* password = "123456789";
//Your IP address or domain name with URL path
const char* serverNameTemp = "http://192.168.4.1/door";
String door;
unsigned long previousMillis = 0;
const long interval = 5000;
#define RedLED        D3                          // GPIO pin assignments. LEDs have a series R and turn
#define GreenLED      D4                          // on when pin is high
#define DoorSwitches  D0                          // There is an external pullup on this
int D0_doorval = 0;
void setup( ) {
  ConfigGPIO( );
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("Connected to WiFi");
void loop( ) {
  if (WiFi.status( ) != WL_CONNECTED) {
  while (WiFi.status( ) != WL_CONNECTED) {
    Serial.print(".");
  if(currentMillis - previousMillis >= interval) {
    // Check WiFi connection status
    if ((WiFiMulti.run() == WL_CONNECTED)) {
      door = httpGETRequest(serverNameTemp);
      //Serial.println("Door: " + door);
      // save the last HTTP GET Request
      Serial.println("WiFi Disconnected");
  delay( 5000 );
  String httpGETRequest( const char* ssid ) {
    WiFiClient client;
    HTTPClient http;
    // Your IP address with path or Domain name with URL path
    http.begin(client, ssid);
    // Send HTTP POST request
    int httpResponseCode = http.GET();
    String payload = "--";
    if ( httpResponseCode > 0 ) {
      //Serial.print("HTTP Response code: ");
      //Serial.println(httpResponseCode);
      payload = http.getString();
      ledStatusIndicators( payload.toInt( ) );
      // Free resources
      http.end();
      return payload;
 void ledStatusIndicators( int D0_doorval ) {
                                      // Read payload from server which read the two door switches which are connected in
                                      // series, one on each 1/2 door, and closed when door closed.
  if ( D0_doorval == 1 ) {            // One or both half door switches open due to pullup
    digitalWrite( RedLED, 1 ) ;       // Red LED on
    digitalWrite( GreenLED, 0 ) ;     // Green LED off
    Serial.println( "Door Open" );
    digitalWrite( RedLED, 0 ) ;
    digitalWrite( GreenLED, 1 ) ;
    Serial.println( "Door Closed" );
void ConfigGPIO( void ) {
  pinMode( DoorSwitches, INPUT );     // DoorSwitches input pin
  pinMode( RedLED, OUTPUT );          // Red and Green LEDs output pins
  pinMode( GreenLED, OUTPUT );
  digitalWrite( RedLED, 0 );         // Turn off LEDs
  digitalWrite( GreenLED, 0 );
Error is (i tried posting as code, post huge amount of crap) -
C:\Users\danaa\Desktop\ESP8266CabinBasementDoor\ClientCabinDoorSense\ClientCabinDoorSense.ino: In function 'String httpGETRequest(const char*)':
C:\Users\danaa\Desktop\ESP8266CabinBasementDoor\ClientCabinDoorSense\ClientCabinDoorSense.ino:77:16: error: control reaches end of non-void function [-Werror=return-type]
   77 |     WiFiClient client;
cc1plus.exe: some warnings being treated as errors
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\danaa\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi
Using library ESP8266HTTPClient at version 1.2 in folder: C:\Users\danaa\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266HTTPClient
exit status 1
Compilation error: control reaches end of non-void function [-Werror=return-type]
Any and all help greatly appreciated.
Regards, Dana.
What does the function return if this condition is false?
    // Free resources
    http.end();
    return payload;
Thank you so much. My pathetic life now can go on.
Regards, Dana.
