Wifi ESP8266
Hello Forums, I am trying to an app that can communicate from arduino to my phone using an ESP8266 module for a project . I have tried a lot of examples and connections shown from youtube but when I am uploading I always get an error message .
Sketch uses 274924 bytes (26%) of program storage space. Maximum is 1023984 bytes.
Global variables use 27188 bytes (33%) of dynamic memory, leaving 54732 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.6
2.6
esptool.py v2.6
Serial port COM5
Connecting……_____
Traceback (most recent call last):
File “C:\Users\seahe\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2/tools/upload.py”, line 25, in
esptool.main(fakeargs)
File “C:/Users/seahe/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/esptool\esptool.py”, line 2653, in main
esp.connect(args.before)
File “C:/Users/seahe/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/esptool\esptool.py”, line 468, in connect
raise FatalError(‘Failed to connect to %s: %s’ % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
“Show verbose output during compilation”
option enabled in File → Preferences.
The code and hardware connections are found https://maker.pro/esp8266/tutorial/esp8266-tutorial-how-to-control-anything-from-the-internet I followed the connections shown in the link above . I have also tried others example but when i upload it always show me a error message . I cant figure out what is the problem .
it will sometimes show “the selected serial port does not exist”
I am using a Mega board . The following attachment is a picture of the settings used to upload to my board.
Thank you.
code?
#include <ESP8266WiFi.h>
const char* ssid = “YOUR_SSID”;//type your ssid
const char* password = “YOUR_PASSWORD”;//type your password
int ledPin = 2; // GPIO2 of ESP8266
WiFiServer server(80);//Service Port
delay(10);
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
// Connect to WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println(“WiFi connected”);
// Start the server
server.begin();
Serial.println(“Server started”);
// Print the IP address
Serial.print(“Use this URL to connect: “);
Serial.print(“http://”);
Serial.print(WiFi.localIP());
Serial.println(”/”);
// Check if a client has connected
WiFiClient client = server.available();
if (!client) {
return;
// Wait until the client sends some data
Serial.println(“new client”);
while(!client.available()){
delay(1);
// Read the first line of the request
String request = client.readStringUntil(’\r’);
Serial.println(request);
client.flush();
// Match the request
int value = LOW;
if (request.indexOf("/LED=ON") != -1) {
digitalWrite(ledPin, HIGH);
value = HIGH;
if (request.indexOf("/LED=OFF") != -1){
value = LOW;
//Set ledPin according to the request
//digitalWrite(ledPin, value);
// Return the response
client.println(“HTTP/1.1 200 OK”);
client.println(“Content-Type: text/html”);
client.println(""); // do not forget this one
client.println("");
client.println("");
client.print("Led pin is now: ");
if(value == HIGH) {
client.print(“On”);
client.print(“Off”);
client.println("
client.println(“Click <a href=”/LED=ON”>here turn the LED on pin 2 ON
client.println(“Click <a href=”/LED=OFF”>here turn the LED on pin 2 OFF
client.println(”");
delay(1);
Serial.println(“Client disconnected”);
Serial.println("");
MolomitZ:
code?
why? he can't upload?
esptool.py v2.6
Why are you using this to upload the program?
The linked tutorial shows how to use a USB>TTL converter or the Arduino itself to with a simple upload of the code from the IDE.
cattledog:
esp8266 arduino core 2.5..+ has the python version of esptool. python is installed with the core
Juraj:
esp8266 arduino core 2.5…+ has the python version of esptool. python is installed with the core
does that mean I have to use python to run the wifi shield ?
ELY1408:
you run python to upload to esp8266. the esptool.py is a python script
did you solved it? was programming fine, but after board update, getting the same error... >:(
using
ESP -
and
UART-TTL
