wifi - LCD - servo - webserver ---> what a mess!
I don't know if this is the write category to post this but I didn't find anyone that is closer to my question...
As written in the title I have an arduino Uno with a WiFi shield on. I also connected an LCD on pins nr 9,8,6,5,3,2 and a servo to A0
What I am experiencing is that wifi losses connection if I use servo.write() int the loop().
Here is the code:
#include <Servo.h>
#include <LiquidCrystal.h>
#include <SPI.h>
#include <WiFi.h>
LiquidCrystal lcd(9,8,6,5,3,2);
// create an instance of the servo library
Servo myServo;
char ssid[] = "HOL ALU WLAN";      // your network SSID (name)
char pass[] = "1a8b17137c";   // your network password
int keyIndex = 0;                 // your network key Index number (needed only for WEP)
char readString[100];
int status = WL_IDLE_STATUS;
WiFiServer server(80);
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  pinMode(1,OUTPUT);
  myServo.attach(14);
   myServo.write(0);
  lcd.begin(16,2);
  lcd.clear();
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue:
    while(true);
 lcd.print("CONNECTING...");
  // attempt to connect to Wifi network:
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  server.begin();
  // you're connected now, so print out the status:
  printWifiStatus();
   lcd.clear();
  lcd.print("CONNECTED");
   // move the servo to the unlocked position
  lcd.setCursor(0,1);
   IPAddress ip = WiFi.localIP();
  lcd.print(ip);
  // listen for incoming clients
  WiFiClient client = server.available();
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    int i=0;
        int starting=-1;
        int ending=-1;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if(i<99) {
          //store characters to string
          readString[i]=c;
          if(c=='=' && starting <0) starting=i;
          if(c=='&' && ending <0) ending=i;
          i++;
        if (c == '\n' && currentLineIsBlank) {
         String speeda="";
          for(int j=starting+1;j<ending;j++){
           speeda+=readString[j];
          int angle=speeda.toInt();
          if(starting>0 & ending>0){
            myServo.write(angle);
          Serial.print("\nSPEED: ");
          Serial.println(speeda);
          Serial.print("\n");
           client.println(angle);
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disonnected");
    readString[0]='\0';
  if ( status != WL_CONNECTED) {
if I comment the line " myServo.write(angle);" wifi doesn't disconnect.
I am using the 1.02 version (as u know the newer versions have problem with the wifi shield)
Does anyone has a clue on what's wrong?
Thanks in advance
How are you powering the servo? Servos are power hogs, as are wifi shields. If the Arduino is powering the servo, moving it probably causes the current delivery to the wifi shield to drop too low.
How far is the servo from the wifi shield? Servos are noisy and may cause interference, resulting in the dropped connection.
What does the LCD have to do with the problem?
I am using the usb cable to power the whole thing...
servo is connected at analog0 pin.
Testing it now with:
a) New wifi firmware
b) Powering through the jack
Ok..
It works ok now!
It doesn't disconnect even if i send the messages to rotate the servo fast.
It must have been the power supply!
