Wifi Led
I have been reading some threads about Wifi problems. However, it is not clear for me if there is a fix.
The only issue I have at the moment is that Wifi led does not work. I see the Yun is connected, I can make telnet to it, but wifi led is always off. So no way yo know whether it is connected or not, what it is very annoying.
The led is not faulty, because when I press the reset it blinks.
Any suggestions?
Thanks in advance
WLAN led is not used to monitor wireless activity. We needed a led to give other feedbacks (like if wifi is working or if you've pressed the reset button) so we ceased from using it to show activity If you are interested, you should post an issue on github proposing your change
[quote author=Federico Fissore link=topic=201784.msg1487038#msg1487038 date=1385727188] WLAN led is not used to monitor wireless activity. We needed a led to give other feedbacks (like if wifi is working or if you've pressed the reset button) so we ceased from using it to show activity If you are interested, you should post an issue on github proposing your change [/quote]
My God... no indication on connection!
Ok, I will add a suggestion. Thanks for feedback
