I was trying to compile the code on this example in order to use UDP functionality with WiFi shield.
The code compiles when using arduino software 1.0.5 and when i select arduino uno board.
When I try to compile for the Arduino Due using 1.5.2 it reports that WiFiUdp.h is missing.
Can WiFiUdp be ported to Arduino due?
If i copy the WiFiUdp.h and WiFiUdp.c to the 1.5.2 the compiler returns these errors:
In file included from c:\users\edit-piaf\desktop\arduino\arduino-1.5.1r2\hardware\tools\g++_arm_none_eabi\bin../lib/gcc/arm-none-eabi/4.4.1/../../../../arm-none-eabi/include/stdio.h:46,
from C:\Users\Edit-Piaf\Desktop\Arduino\arduino-1.5.1r2\libraries\WiFi/utility/debug.h:13,
from C:\Users\Edit-Piaf\Desktop\Arduino\arduino-1.5.1r2\libraries\WiFi\WiFiClient.cpp:6:
c:\users\edit-piaf\desktop\arduino\arduino-1.5.1r2\hardware\tools\g++_arm_none_eabi\bin../lib/gcc/arm-none-eabi/4.4.1/../../../../arm-none-eabi/include/sys/types.h:93: error: conflicting declaration 'typedef short unsigned int u_short'
C:\Users\Edit-Piaf\Desktop\Arduino\arduino-1.5.1r2\libraries\WiFi\utility/socket.h:71: error: 'u_short' has a previous declaration as 'typedef uint16 u_short'
C:\Users\Edit-Piaf\Desktop\Arduino\arduino-1.5.1r2\libraries\WiFi\WiFiClient.cpp: In member function 'virtual int WiFiClient::read(uint8_t*, size_t)':
C:\Users\Edit-Piaf\Desktop\Arduino\arduino-1.5.1r2\libraries\WiFi\WiFiClient.cpp:107: error: no matching function for call to 'ServerDrv::getDataBuf(uint8_t&, uint8_t*&, size_t*)'
C:\Users\Edit-Piaf\Desktop\Arduino\arduino-1.5.1r2\libraries\WiFi\utility/server_drv.h:26: note: candidates are: static bool ServerDrv::getDataBuf(uint8_t, uint8_t*, uint16_t*)
Thank you.
Mirza
