Hi guys, I have a helteck wifi lora 32 v2 and Im trying to do a communication between 2 of them. The first one is only sending messages by Lora but the second is receveing messages by Lora and sending it by MQTT. I have some functions to reconnection and to check the connections between the devices. All works good, but after a while both devices reboot (not at the same time). How can I do? I'm going to paste my codes. I hope you can help me. Thank you.
/*------LIBRERIAS--------------------*/
#include <WiFi.h>
#include <PubSubClient.h>
#include <EEPROM.h>
#include "heltec.h"
/*----VARIABLES INTERNET ---------------*/
const char* ssid = "Nexxt_B5486C";
const char* password = "di-control";
const char* mqtt_server = "192.168.0.102";
const char* deviceID = "ESP32_Modulo1";
const char* topic_prueba = "esp32/m1/in";
const char* topic_out = "esp32/m1/out";
const char* topic_validacion = "watchdog";
/*-------OBJETOS DE LIBRERIAS ----------*/
WiFiClient espClient;
PubSubClient client(espClient);
#define BAND 915E6
/*------- VARIABLES FISICAS -----------*/
const int gpio13Led = 25; //LED COMUNICACION WIFI
const int gpioLora = 32; //LED COMUNICACION LORA
const int gpio12Relay = 17; //SALIDA
const int gpio33boton = 33; //ENTRADA
int estadoboton = LOW;
/*------- VARIABLE CALLBACK------------*/
int topic_size = 40; //variable a modificar dependiendo el largo del topic en Node red al que esta inscrito
char msg[40];
char topico[40];
char publish[40];
/*--------VARIABLES SEND DATA MQTT----------*/
unsigned long currentMillis;
unsigned long reloj = 0;
int tempo = 0;
int rest = 3; //Manda msj cada 5 seg
/*--------VARIABLES WATCHDOG MQTT----------*/
unsigned long reloj2 = 0;
int tempo2 = 0;
int rest2 = 20; //Sino recibe señal del watchdog en 20 seg
/*--------VARIABLES WATCHDOG LORA----------*/
unsigned long reloj3 = 0;
int tempo3 = 0;
int rest3 = 20; //Sino recibe señal del watchdog en 20 seg
/*--------VARIABLES SEND DATA LORA----------*/
unsigned long reloj4 = 0;
int tempo4 = 0;
int rest4 = 3; //Sino recibe señal del watchdog en 5 seg
/*-------VARIABLES CONVERSION LORA --------*/
String entrada = "";
char inChar = 0;
char aux[10];
char* p = 0;
int cuenta_receive = 0;
//-----OLED---------//
String rssi = "";
/*-------CIERRE DE VARIABLES --------*/
void setup_wifi() {
delay(10);
digitalWrite(gpio13Led, LOW);
WiFi.disconnect();
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
//Serial.println("Setup wifi");
for (int i = 0; i < 120; i++) {
if (WiFi.status() != WL_CONNECTED) {
delay(100);
digitalWrite(gpio13Led, HIGH);
//Serial.println("IP address: ");
//Serial.println(WiFi.localIP());
void callback(char* topic, byte* payload, unsigned int length) {
memcpy(msg, payload, length);
msg[length] = '\0';
topic[topic_size] = '\0';
if (strncmp(topic, topic_prueba, topic_size) == 0) {
if (strncmp(msg, "ON", length) == 0) {
digitalWrite(gpio12Relay, HIGH);
} else if (strncmp(msg, "OFF", length) == 0) {
digitalWrite(gpio12Relay, LOW);
if (strncmp(topic, topic_validacion, topic_size) == 0) {
if (strncmp(msg, "HEY", length) == 0) {
tempo2 = 0;
for (int i = 0; i <= length; i++) {
payload[i] = '\0';
msg[i] = '\0';
for (int i = 0; i <= topic_size; i++) {
topic[i] = '\0';
void reconnect() {
while (!client.connected()) {
if (client.connect(deviceID)) {
client.subscribe(topic_prueba);
client.subscribe(topic_validacion);
digitalWrite(gpio13Led, HIGH); //Para observar el estado de conexion
void OLED() {
Heltec.display->init();
//Heltec.display->flipScreenVertically();
Heltec.display->setFont(ArialMT_Plain_10);
Heltec.display->clear();
Heltec.display->drawString(0, 0, "DICONTROL");
Heltec.display->drawString(0, 10, "Creamos soluciones tecno");
Heltec.display->drawString(0, 20, "4779149289");
Heltec.display->display();
void LoRaData() {
Heltec.display->setTextAlignment(TEXT_ALIGN_LEFT);
Heltec.display->drawString(0, 15, "Mensajes Recib: " + String(cuenta_receive));
rssi = "Fuerza Señal Recib: " + String(LoRa.packetRssi(), DEC);
Heltec.display->drawString(0, 0, rssi);
void onReceive(int packetSize) {
for (int i = 0; i < packetSize; i++) {
inChar = LoRa.read();
aux[i] = inChar;
entrada = entrada + aux;
if (aux[0] == 'T') {
p = strtok(aux, "T*");
cuenta_receive = atoi(p);
tempo3 = 0;
//Serial.print("RECEIVER: ");
//Serial.println(cuenta_receive);
inChar = 0;
*p = 0;
entrada = "";
for (int i = 0; i < 10; i++) {
aux[i] = '\0';
void setup(void) {
//EEPROM.begin(512);
pinMode(gpio13Led, OUTPUT);
pinMode(gpio12Relay, OUTPUT);
pinMode(gpioLora, OUTPUT);
setup_wifi();
client.setServer(mqtt_server, 1884);
client.setCallback(callback);
Heltec.begin(true /*DisplayEnable Enable*/, true /*Heltec.LoRa Disable*/, true /*Serial Enable*/, true /*PABOOST Enable*/, BAND /*long BAND*/);
LoRa.onReceive(onReceive);
LoRa.receive();
OLED();
void loop(void) {
currentMillis = millis();
LoRaData();
setup_wifi(); //se cambio el setup y se agregaron estas condiciones
//TIMER SEND DATA MQTT
if (currentMillis - reloj >= 1000) {
tempo++;
reloj = currentMillis;
if (tempo >= rest) {
itoa(cuenta_receive,publish,10);
client.publish(topic_out, publish);
tempo = 0;
//TIMER WATCHDOG MQTT
if (currentMillis - reloj2 >= 1000) {
tempo2++;
reloj2 = currentMillis;
if (tempo2 >= rest2) {
//TIMER WATCHDOG LORA
if (currentMillis - reloj3 >= 1000) {
tempo3++;
reloj3 = currentMillis;
if (tempo3 >= rest3) {
digitalWrite(gpioLora, LOW);
digitalWrite(gpioLora, HIGH);
if (currentMillis - reloj4 >= 1000) {
tempo4++;
reloj4 = currentMillis;
if (tempo4 >= rest4) {
LoRa.beginPacket();
LoRa.setTxPower(14, RF_PACONFIG_PASELECT_PABOOST); //ESTO HABILITA MANDAR LA INFO
LoRa.print("T");
LoRa.print(cuenta_receive);
LoRa.endPacket("*");
//Serial.print("SENDER: ");
LoRa.receive(); //ESTO HABILITA RECIBIR LOS DATOS
rest4 = random(2) + 3;
tempo4 = 0;
//TIMER SEND DATA LORA//
if (!client.connected()) {
reconnect();
if (!client.loop())
client.connect(deviceID);
//-------LIBRERIA--------//
#include "heltec.h"
//-------OBJETO DE LIBRERIA------//
#define BAND 915E6
//-------VARIABLE PARA INT DESDE RECEIVER-------//
char inChar = 0;
char aux[10];
char *p = 0;
//------ENTRADA DEBOUNCE----------//
const int botonIncremento = 33;
int cuenta = 0;
int estadoBotonIncremento;
int estadoBotonAnteriorIncremento;
int contador = 0;
//--------SALIDA---------//
const int salida = 25;
//-----TIMER SEND DATA---------//
int tempo = 0;
int rest = 3; //Manda msj cada 3 seg y se recibe igual
//-----TIMER COMPROBACION DATOS---------//
int tempo2 = 0;
int rest2 = 5; //Sino recibe msj en 10 seg se apaga led
String rssi = "";
//------ FIN DE VARIABLES------//
void counter_plus() {
estadoBotonIncremento = digitalRead(botonIncremento);
if (estadoBotonIncremento != estadoBotonAnteriorIncremento) {
if (estadoBotonIncremento == HIGH) {
contador++;
delay(10);
estadoBotonAnteriorIncremento = estadoBotonIncremento; // guardamos el estado del botón
if (contador >= 30000) {
contador = 0;
void OLED() {
void LoRaData() {
Heltec.display->drawString(0, 15, "Msj mandado: " + String(contador));
Heltec.display->drawString(0, 30, "Msj comprobado: " + String(cuenta_receive));
aux[i] = inChar;
if (aux[0] == 'T'){
p = strtok (aux,"T*");
counter_plus();
inChar = 0;
*p = 0;
entrada = "";
aux[i] = '\0';
Heltec.begin(true /*DisplayEnable Enable*/, true /*LoRa Disable*/, true /*Serial Enable*/, true /*PABOOST Enable*/, BAND /*long BAND*/);
LoRa.receive(); //ACTIVA MODO RECEPCION
pinMode(salida, OUTPUT);
pinMode(botonIncremento, INPUT);
OLED();
counter_plus();
LoRaData();
tempo++;
LoRa.beginPacket();
LoRa.print("T");
LoRa.print(contador);
LoRa.print("*");
LoRa.endPacket();
Serial.println(contador);
rest = random(2) + 3;
tempo = 0;
tempo2++;
if (contador - 10 < cuenta_receive) {
digitalWrite(salida, HIGH);
digitalWrite(salida, LOW);
tempo2 = 0;
