Wifi mac address As String to Char*
What am I doing wrong and how do I correct it ?
String s = WiFi.macAddress();
snprintf (msg, 75, "Mac Address is %s",s);
Serial.println(msg);
The above gives me an error.
But this works.
char* s = "xx:xx:xx:xx:xx";
snprintf (msg, 75, ""Mac Address is %s"",s);
What should I do to use it with snprintf?
s.c_str()
Thanks for the reply.
Already tried but didn't work
did something like this,
try 1)
snprintf (msg, 75, "Mac Address is " +WiFi.macAddress.c_str());
try 2)
char* s = WiFi.macAddress.c_str();
snprintf (msg, 75, "Mac Address is %s " s );
neither worked. Did I miss anything?
snprintf (msg, 75, "Mac Address is %s ", s );
arguments of snprintf are target, target size, format string and then format parameters. so not + but ,
Just do this:
Serial.print("Mac Address is ");
Serial.println(WiFi.macAddress());
It's silly to go to so much trouble just to try to set up your message for a single Serial.println() call.
pert:
Just do this:
I did that , But I don't use msg buffer for printing in my project. I did Serial.print just to simplify and test.
My project specifically needs use of snprintf (msg, 75, "Mac Address is %s " s ).
OK, I understand now.
Juraj:
Can you please help me with an example.
try 2, is ok. only the , is missing
I am curious, what output can’t take two prints? You could use CStringBuilder from my StreamLib
Finally could get it to work.
Here is the code.
#include <ESP8266WiFi.h>
char* mychar;
char msg[200];
Serial.begin(230400);
String s = WiFi.macAddress(); // Use Mac ID as a mychar
int slen = ss.length();
mychar = &s[0];
snprintf (msg, 75, “Mac Address is %s”, mychar);
delay(100);
mychar = &s[0];
is same as
mychar = s.c_str();
and I am still curious, what output you think can't take two prints?
Sure , If someone here could really explain. I am not sure too.
I_think:
we don't know how do you want to use the resulting string
