Wifi not connecting
I want to setup a Wifi connection with a NodeMCU to control WS2812 LEDs but the program does not connect to my Wifi - the code compiles fine with no errors.
Code used:
#include <FastLED.h>
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#include <NTPClient.h>
#include <ESP8266WebServer.h>
#include <ArduinoOTA.h>
#include <Wire.h>
#include <EEPROM.h>
char ssid[32] = "MY_SSID";
char password[32] = "MY_Password";
void setupWiFi() {
  WiFi.begin(ssid, password);
  Serial.print("Connecting to WiFi");
  unsigned long start = millis();
  while (WiFi.status() != WL_CONNECTED && millis() - start < 15000) {
    delay(500); Serial.print(".");
  if (WiFi.status() == WL_CONNECTED) {
    Serial.println("\nConnected: " + WiFi.localIP().toString());
    Serial.println("\nWiFi failed.");
Can figure out what the problem is.
Thanks
Presuming you have put your correct SSID and Password on the lines below, you may be trying to connect to a 5.0GHz net. If so, try a 2.4GHz.
You haven't told what happens. You keep getting the dots until the 15s are completed?
Add WiFi Mode Explicitly and Print Detailed Connection Status.
void setupWiFi() {
  WiFi.mode(WIFI_STA);  // Ensure in Station Mode
    Serial.print(" Status: "); Serial.println(WiFi.status());
    Serial.println("\nConnected to WiFi.");
    Serial.print("IP address: ");
    Serial.println("\nWiFi connection failed.");
Thank for the answers. Yes, I'm getting the dots and afterwards a "WiFi failed." The SSID and and the passwort are correct and I specifically set the network tpo 2.4 GHz only.
I added the line ahsrabrifat suggested but still end up with "WiFi failed."
In case it matters encryption is WPA2
I added
Serial.print("Status: ");
and get as return WL_NO_SSID_AVAIL = 1
I went back to a simple code
const char* ssid = "Guest";      // Change this
const char* password = "xxxxxx";     // And this
  delay(100);
  //wifi_set_phy_mode(PHY_MODE_11G);
  Serial.print("Connecting");
    Serial.print(".");
    Serial.println("\nConnected!");
    Serial.print("IP Address: ");
    Serial.println("\nFailed to connect.");
void loop() {}
and it connects fine.
Changing my code to
does not work and givers an error
error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
  228 |       strncpy(ssid, server.arg("ssid").c_str(), sizeof(ssid));
I was waiting for someone else with more programming skills to join in...
We don't have your entire sketch, just the snippet of post #1, so it's not clear for me if the error comes from another line in your code or from a function inside one of the libraries. But the compiler rages against a conversion between a constant pointer and a pointer. So my next step would be to change
to
and see what happens...
That gives
18:08:32.844 -> Status: 0
I attached the entire code
WordClock_ESP8266_OTA_UI1.ino (7.2 KB)
there's a way to scan for networks. might help to know that your board is seeing yours
// https://openlabpro.com/guide/scanning-of-wifi-on-esp32-controller/
static void
_wifiScan (void)
    printf ("%s:\n", __func__);
    // WiFi.scanNetworks will return the number of networks found
    WiFi.mode (WIFI_OFF);
    int nNet = WiFi.scanNetworks ();
    if (nNet == 0) {
        printf ("  %s: no networks found\n", __func__);
    else {
        printf ("  %s: %2d networks found\n", __func__, nNet);
        if (0 > nNet)
            nNet = -nNet;
        for (int i = 0; i < nNet; ++i) {
            printf (" %s: %2d - %s (%d) %s\n", __func__, i,
                WiFi.SSID (i).c_str (),
                WiFi.RSSI (i),
                WiFi.encryptionType (i) == WIFI_AUTH_OPEN ? "open" : "locked");
Tried the below code to scan the networks and see nothing comming back in the serial monitor.
  WiFi.disconnect(); // Disconnect from any previous connection
  delay(100);        // Small delay to settle
  Serial.println("Scanning for networks...");
  int numberOfNetworks = WiFi.scanNetworks();
  if (numberOfNetworks == 0) {
    Serial.println("No networks found.");
    Serial.print(numberOfNetworks);
    Serial.println(" network(s) found:");
    Serial.println("-----------------------");
    for (int i = 0; i < numberOfNetworks; ++i) {
      Serial.print("Network name: ");
      Serial.println(WiFi.SSID(i));
      Serial.print("Signal strength (RSSI): ");
      Serial.println(WiFi.RSSI(i));
void loop() {}
Even the simplest program shows no ouitput in the console, getting mad
  Serial.println("Hello from NodeMCU!");
void loop() {}
is the serial monitor set to the same speed as the code (i.e. 115200)?
Did you double check your SSID and Password?
sounds like a print problem
I have the same error when antenna is disconnected, maybe your transmitter is not good.
What router or access point do you have?
Sorry, I was busy and had no time to answer.
Nevertheless, I first did a reset for the controller and played around with the code that was not working:
void loop() {}
The issue was the
After I set it to
delay(2000);
I got first the response
WL_DISCONNECTED     = 7
and afterwards
WL_CONNECTED     = 1
With regards to the the problem in the first posting I figured there is a part in the code that passes the ssid and passwort, took that out and the Wifi connects fine.
Thanks for any help :+1:
