Wifi Power Outage Detector
Hi, community of Arduino.
I'm kind of new to this kind of project so any help is appreciated.
I am making a wifi power outage detector, I have the schematic plan and the program is already made, but I need to know if I'm doing it right or if there was a better way for doing it.
I intend on using a ATMEGA328P-PU, Adafruit's CC3000 wifi breakout and a LM35DZ for the temp
I'm not sure if using a relay will effectively switch between the mains power and the battery. The 4.8V battery is supposed to work directly with the chip and it will be more effective than using a voltage regulator. Sleeping saves the battery. It will connect to a mobile wifi access and upload the power status and the temperature to Xively.
The schematic is attached to the post.
Here's the code:
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <stdlib.h>
#include <string.h>
#include <avr/sleep.h>
#include <avr/wdt.h>
#include <debug.h>
#define ADAFRUIT_CC3000_IRQ 3
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT, SPI_CLOCK_DIV2);
#define WLAN_SSID "SSID"
#define WLAN_PASS "****"
#define WLAN_SECURITY WLAN_SEC_WPA2
#define WEBSITE "api.xively.com"
#define API_key "yourAPIKey"
#define feedID "yourFeedID"
uint32_t ip;
#define redLed 6
#define greenLed 7
#define yellowLed 8
#define powerPin 2
#define tempPin A5
#define sleepTime 450
volatile byte wdt = 0;
void setup(){
  pinMode(redLed, OUTPUT);
  pinMode(greenLed, OUTPUT);
  pinMode(yellowLed, OUTPUT);
  pinMode(powerPin, INPUT);
  pinMode(tempPin, INPUT);
  Serial.println(F("\nInitializing..."));
  if(!cc3000.begin()){
    Serial.println(F("Couldn't begin()! Check your wiring!"));
    while(1);
  setup_watchdog();
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  delay(10);
void loop(){
  int powerState = digitalRead(powerPin);
  while(powerState == true){
    digitalWrite(greenLed, HIGH);
    digitalWrite(yellowLed, HIGH);
    ip = 0;
    Serial.print(WEBSITE);Serial.print(F("->"));
    while(ip == 0){
      if(!cc3000.getHostByName(WEBSITE, &ip)){
        Serial.println(F("Couldn't resolve!"));
    cc3000.printIPdotsRev(ip);
    int tempC = (5.0 * analogRead(tempPin) * 100.0) / 1024.0;
    int length = 0;
    String data = "";
    data = data + "\n" + "{\"version\":\"1.0.0\",\"datastreams\" : [ {\"id\" : \"Temperature\",\"current_value\" : \"" + String(tempC) + "\"},"
    + "{\"id\" : \"Power Status\",\"current_value\" : \"" + String(powerState) + "\"}]}";
    length = data.length();
    Adafruit_CC3000_Client client = cc3000.connectTCP(ip, 80);
    if(client.connected()){
      Serial.println("Connected!");
      client.println("PUT /v2/feeds/" + String(feedID) + ".json HTTP/1.0");
      client.println("Host: api.xively.com");
      client.println("X-ApiKey: " + String(API_key));
      client.println("Content-Length: " + String(length));
      client.print("Connection: close");
      client.println();
      client.print(data);
      client.println();
    while(client.connected()){
      while(client.available()){
        char c = client.read();
        Serial.print(c);
    client.close();
    cc3000.disconnect();
    digitalWrite(yellowLed, LOW);
    delay(300000);
    digitalWrite(greenLed, LOW);
  while(powerState == false){
    digitalWrite(redLed, HIGH);
    ip = 0;
    while(ip == 0){
    int length = 0;
    String data = "";
      client.println();
      client.print(data);
      client.println();
        Serial.print(c);
    client.close();
    digitalWrite(redLed, LOW);
    system_sleep();
void system_sleep() {
  for(int x = 0; x < sleepTime; x++){
    digitalWrite(9,HIGH);
    delay(100);
    digitalWrite(9,LOW);
    delay(10);
    byte dummy_0 = DDRB;
    byte dummy_1 = DDRD;
    byte dummy_2 = TWSR;
    byte dummy_3 = TWBR;
    byte dummy_4 = SPCR;
    byte dummy_5 = SPSR;
    PRR = 0xEF;
    ADCSRA |= (0<<ADEN);
    DDRB = 0x00;
    DDRD = 0x00;
    sleep_enable();
    sleep_mode();
    // sleeping ...
    sleep_disable();
    wdt=0;
    PRR = 0x00;
    ADCSRA |= (1<<ADEN);
    DDRB = dummy_0;
    DDRD = dummy_1;
    TWSR = dummy_2;
    TWBR = dummy_3;
    SPCR = dummy_4;
    SPSR = dummy_5;
void setup_watchdog() {
  MCUSR = 0x00;
  WDTCSR |= (1<<WDCE) | (1<<WDE);
  WDTCSR = (1<<WDP3) | (1<<WDP0);
  WDTCSR |= (1<<WDIE);
ISR(WDT_vect) {
  wdt++;
Thank you!
Have you considered using an Uninterrupatble Power Supply to fill the gap during a power failure?
Well, I'm a DIY kind of guy and those I found were very expensive, so I would rather use a relay and a battery pack instead.
I'm building this so I can monitor the power and temp remotely, because we go there 2-3 times a month and power outage are frequent and can last from a small 2 hours to a whole week.
