Hello,
I am using the WiFi included in the nano 33 IoT board with an external SD card reader (two SPI devices, right?). The issue I get occurs randomly after X minutes when I use both WiFi and SD card. After some investigation, I found out the WiFi status is always WL_NO_SHIELD when the WiFi got stuck. Moreover, usually it is a permanent stuck but sometimes the WiFi automatically restores after some seconds. I tried without SD card plugged (or not initialized) and the issue seems not occurring.
I do not share the code yet because I don't know if it is really helpful but will do if needed. After a research on the web and my tests, it seems a conflict caused by the two SPI devices used together. What do you guys think? I am pretty new in Arduino world so I would like to have your suggestions on how I should handle multiple SPI devices like WiFi and SD card readers because I feel I am missing something basic on this topic. I plugged the SD in this way:
| SD | Arduino |
| 3v3 | 3v3 |
| CS | D10 |
| MOSI | D11 |
| CLK | D13 |
| MISO | D12 |
| GND | GND |
I am using SD, WiFiNINA and WiFiUdp arduino standard libraries and started frm example codes available on the arduino website used to:
- Read/write files on SD
- Send/receive UDP messages
Thank you for your support.
Davide
