Hello there.
I am using Arduino WiFi rev2, the Arduino IDE, and Windows 10 computer.
I was getting this error while uploading my robot code:
avrdude: jtag3_edbg_send(): failed to send command to serial port
avrdude: failed to write 64 bytes to USB port
This would loop until the IDE crashed, and this was happening every time I tried to upload the code. I figured out what was wrong, so I won't post the code. The general gist of the code was: Connect to WiFi and Blynk servers, when data is received (Blynk Bridge widget), move accordingly.
I fixed this error by uploading a Blink (not Blynk) sketch:
Blink
Turns an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
the correct LED pin independent of which board is used.
If you want to know what pin the on-board LED is connected to on your Arduino
model, check the Technical Specs of your board at:
https://www.arduino.cc/en/Main/Products
modified 8 May 2014
by Scott Fitzgerald
modified 2 Sep 2016
by Arturo Guadalupi
modified 8 Sep 2016
by Colby Newman
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/Blink
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
This worked for some reason, and now everything is working fine.
I just wanted to post this to help others with the same issue. This may be a repost, but I looked for a long time and could not find anything like this.
