Hi, I’m having trouble connect to wifi with my Wifi Rev2. My IDE is 1.8.13, the firmware is currently 1.2.1. I had been using 1.0.0 firmware and that successfully connected to the wifi network but the post request I was trying to send was not going through even after successfully connecting to the server. What configuration of firmware/IDE/wifi library is necessary for sending post requests with the Wifi Rev 2 and why does updating my firmware to anything but 1.0.0 prevent my program from connecting to wifi?
#include <SPI.h>
#include <WiFiNINA.h>
#include "arduino_secrets.h"
#include "DHT.h"
#define DHTPIN 2
char ssid[] = SECRET_SSID;
char pass[] = SECRET_PASS;
int status = WL_IDLE_STATUS;
char server[] = "www.mywebsite.com";
unsigned long lastConnectionTime = 0;
const unsigned long postingInterval = 2L * 1000L;
WiFiClient client;
DHT dht(DHTPIN, DHTTYPE);
pinMode(WATER_PUMP_PIN, OUTPUT);
dht.begin();
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
// attempt to connect to WiFi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// wait 5 seconds for connection:
delay(5000);
// you're connected now, so print out the data:
Serial.println("You're connected to the network");
printWiFiData();
if (millis() - lastConnectionTime > postingInterval) {
httpRequest();
void printWiFiData() {
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP address : ");
Serial.println(ip);
Serial.print("Subnet mask: ");
Serial.println((IPAddress)WiFi.subnetMask());
Serial.print("Gateway IP : ");
Serial.println((IPAddress)WiFi.gatewayIP());
// print your MAC address:
byte mac[6];
WiFi.macAddress(mac);
Serial.print("MAC address: ");
printMacAddress(mac);
void httpRequest() {
client.stop();
Serial.println("\nStarting connection to server...");
String PostData = String("{\"variable\":\"temperature\", \"value\":") + "404.2" + String(",\"unit\":\"C\"}");
if (client.connect(server,80)) {
Serial.println("connected to server");
// Make a HTTP request:
client.println("POST /data? HTTP/1.1");
client.println("Host: www.mywebsite.com");
client.println("_ssl: false");
client.println("Content-Type: application/json");
client.print("Content-Length: ");
client.println(PostData.length());
client.println();
client.print(PostData);
lastConnectionTime = millis();
else {
// if you couldn't make a connection:
Serial.println("connection failed");
void printMacAddress(byte mac[]) {
for (int i = 5; i >= 0; i--) {
if (mac[i] < 16) {
Serial.print("0");
Serial.print(mac[i], HEX);
if (i > 0) {
Serial.print(":");
