I took my Arduino Wifi Rev 2 module to a friend who has Windows 10 Arduino IDE version 1.8.13 running. It worked fine; downloaded sketches.etc. I also used my Chrome OS laptop loaded with Linux IDE version 1.8.19 and successfully loaded sketches into both an Arduino Uno module and a Nano module that he has.
I have selected in Board Manager under Tools the Wifi Rev 2 board type. I believe the boards and library are both updated with latest software.
When I plug in the Wifi module I see no change under the Manage USB devices; with the other Arduino boards the Chromebook immediately recognizes the devices (USB 2.0). With the Wifi module the Port stays greyed out in IDE.
Since the cabling and IDE software works with other Arduino modules and not the Wifi Rev 2 I am thinking there is something amiss inside the Linux IDE. Or could this be a firmware issue with the Wifi Rev 2?
Any suggestions welcomed.
Well it is obvious I am in over my head. I know only a small amount about terminal mode and Linux file hierarchy. I was hoping to get by this and just do some Arduino programming.
I cannot copy and paste in terminal mode as the commands are not working for whatever type of terminal Chrome OS uses.
So I made a screenshot but cannot figure out how to imbed the screenshot in this reply. This is my first Chromebook and have had it for a whole three days.
I will have to step away and regroup before I can give you some meaningful data pertaining to my difficulties.
OK, things are working better for me today after sleeping on it....
Here are the error messages in terminal mode:
edthetermite@penguin:~$ sudo ~/.arduino15/packages/arduino/hardware/megaavr/1.8.7/scripts/create_dfu_udev_rule~
sudo: /home/edthetermite/.arduino15/packages/arduino/hardware/megaavr/1.8.7/scripts/create_dfu_udev_rule~: command not found
edthetermite@penguin:~$ dir
Arduino arduino-1.8.19-linux64.tar.xz Desktop
edthetermite@penguin:~$ cd Arduino
edthetermite@penguin:~/Arduino$ dir
libraries
edthetermite@penguin:~/Arduino$ cd libraries
edthetermite@penguin:~/Arduino/libraries$ dir
readme.txt
edthetermite@penguin:~/Arduino/libraries$ cd /
edthetermite@penguin:/$ dir
bin dev home lib32 libx32 mnt proc run srv tmp var
boot etc lib lib64 media opt root sbin sys usr
edthetermite@penguin:/$ cd home
edthetermite@penguin:/home$ dir
arduino-1.8.19-linux64.tar.xz edthetermite
edthetermite@penguin:/home$ cd edthetermite
edthetermite@penguin:~$ cd ~/.arduino19/packages/arduino/hardware/megaavr/1.8.19/scripts/create_dfu_udev
-bash: cd: /home/edthetermite/.arduino19/packages/arduino/hardware/megaavr/1.8.19/scripts/create_dfu_udev: No such file or directory
edthetermite@penguin:~$ cd ~/.arduino15/packages/arduino/hardware/megaavr/1.8.7/s
I am not sure what the difference is between: edthetermite@penguin:~$ and edthetermite@penguin:~/. Hopefully my problem is not being in the correct directory when I issued the command you suggested.
I am hopeful on getting this thing straightened out.
Aargh. Unfortunately I don't know what would cause this error. udev rules are quite mysterious to me in general. I usually just copy/paste commands from Stack Exchange until the port starts working. With the whole Chrome OS factor thrown into the mix it gets even more confusing.
Hopefully one of the other forum members will have some advice for you.
The roadblock may be impenetrable. I am out of my element certainly. Lol
Appreciate your help getting the IDE installed!
Update: Chrome OS/Chromebook became unstable after downloading and launching Linux Arduino IDE (ver. 1.8.19). Apps were disappearing from Launcher, even Google Play Store started disappearing from Google Apps listing. And what was really wonky was the Developer settings area under Advanced Settings disappeared. You could see it under a different user but not my user area. Time to move on to a different Arduino platform!
