Wifi server,client,tcp speed.
Hi
I have a problem with response time.
I send string to arduino but response time 5sec.
Conection speed response good response time 1sec maybe and send the connection welcome message.
What the wrong why sloow?
#include <ESP8266WiFi.h>
#include <WebSocketClient.h>
#include <WiFiClient.h>
/* Set these to your desired credentials. */
const char *AP_ssid = "Ecet";
const char *AP_passkey = "12345678";
int status = WL_IDLE_STATUS;
boolean alreadyConnected[2] ; // whether or not the client was connected previously
WiFiServer server(6000);
WiFiClient client ;
#define Config_Led D2
    //Serial.begin(115200);
   // Serial.println();
   // Serial.println("\nConfiguring access point...");
    WiFi.mode(WIFI_AP);
    WiFi.softAP(AP_ssid, AP_passkey);
    delay(10000);
    IPAddress myIP = WiFi.softAPIP();
   // Serial.print("AP IP address: ");
    //Serial.println(myIP);
   // Serial.println("\nStarting server...");
    // start the server:
    server.begin();
   // Serial.println("\nServer Started.");
    String szoveg = "safe";
    unsigned int i;
    for (i= 0; i<2; i++)
        // wait for a new client:
        if (!client)
            client = server.available();
            if (client.status() == CLOSED)
                client.stop();
               // Serial.print("\nConnection closed on client: "  );
               // Serial.println(i);
                alreadyConnected[i] = false;
                if(!alreadyConnected[i]) // when the client sends the first byte, say hello:
                    // clean out the input buffer:
                    client.flush();
                    //Serial.print("\nNew client: ");
                    client.println("Hello, client !");
                    alreadyConnected[i] = true;
                if (client.available())
                    // read the bytes incoming from the client:
                    String data =  client.readStringUntil('\n');
                    // echo the bytes back to the client:
                    if(szoveg.compareTo(data)==0){
                         client.flush();
                         client.println("ok")+"\n";
                        //client[i].println("ok1");
                        //client[i].println("ok2");
                        //client[i].println("ok3");
                        //client[i].println("ok4");
                        //Serial.println("A ket szoveg megegyezik");
                        //Serial.println("Nem egyformak");
                    // echo the bytes to the server as well:
                    client.flush();
                    client.println("nemok")+"\n";;
                   // Serial.println(data);
there is no point in stopping a closed client
readStringUntil will wait a second for the next byte. if n is not sent then you loose a second
flush() doesn’t clear the input buffer.
it immediately sends the data from output buffer.
https://www.arduino.cc/reference/en/language/functions/communication/stream/streamflush/
I don’t understand your algorithm with the alreadyConnected array.
WiFiClient clients[2];
  WiFi.mode(WIFI_AP);
  server.begin();
  for (int i = 0; i < 2; i++) {
    if (!clients[i]) {
      clients[i] = server.available();
      if (clients[i]) {
        clients[i].println("Hello, client !");
    if (clients[i] && clients[i].available()) {
      String data = clients[i].readStringUntil('\n');
      if (szoveg.compareTo(data) == 0) {
        clients[i].println("ok");
        clients[i].println("nemok");
Thanks your answer.
Here is the response fast but below unfortunately yet until all of them 5 secundum.
    if (!clients[i]) {
      if (clients[i]) {
rogers1976:
Thanks your answer.
if (!clients[i]) {
      if (clients[i]) {
        clients[i].println(“Hello, client !”);
how do you send the data? send \n at the end
Yes with Android studio.
Thread3(String message) {
            this.message = message;
        @Override
        public void run() {
            output.write(message);
            output.flush();
            runOnUiThread(new Runnable() {
                @Override
                public void run() {
                    tvMessages.append("client: " + message + "\n");
                    etMessage.setText("");
is output.write(message); the sending to server?
has the sent message '\n' at the end?
you can test the server with telnet client
wowww thanks alll :smiley: :smiley: :smiley: :smiley: :smiley:
not sendig the '\n'
class Thread3 implements Runnable {
        private String message;
        @Override
        public void run() {
            output.write(message+'\n'); here :)))
            output.flush();
                @Override
                public void run() {
thanks alll :slight_smile:
rogers1976:
not sendig the '\n'
@Override
        public void run() {
            output.flush();
                @Override
                public void run() {
thanks alll :)
readString/until('\n')
if the \n is not there the timeout waits a second for it
