Wifi Shield and Motor Shield working together
I am currently involved in a project which needs to have 4 led’s and one stepper motor to be turned on/off independently over wifi.
Just to mention Im using an Uno r3, official Wifi shield and official motor shield.
I have the 4 led’s working on pins A2-A5 or in my code pins (16-19) leaving free all digital pins and have set up my stepper motor to pins 9,8,6,5. When i go to the ip address i can turn off/on each LED independently but with the stepper motor it either judders and does not move or nothing at all.
I have posted my code so far below, would really appreciate any help or advice. Thanks
WiFi Web Server LED Blink
A simple web server that lets you blink an LED via the web.
This sketch will print the IP address of your WiFi Shield (once connected)
to the Serial monitor. From there, you can open that address in a web browser
to turn on and off the LED on pin 9.
If the IP address of your shield is yourAddress:
http://yourAddress/H turns the LED on
http://yourAddress/L turns it off
This example is written for a network using WPA encryption. For
WEP or WPA, change the Wifi.begin() call accordingly.
Circuit:
  • WiFi shield attached
  • LED attached to pin 9
created 25 Nov 2012
by Tom Igoe
#include <SPI.h>
#include <WiFi.h>
#include <Stepper.h>
char ssid = “username”; // your network SSID (name)
char pass = “password”; // your network password
int keyIndex = 0;
int delaylegnth = 7;
int state = 0;
int x = 0;
// your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
Serial.begin(9600); // initialize serial communication
pinMode(16, OUTPUT); // set the LED pin mode
pinMode(17, OUTPUT); // set the LED pin mode
pinMode(18, OUTPUT); // set the LED pin mode
pinMode(19, OUTPUT); // set the LED pin mode
//establish motor direction toggle pins
pinMode(5, OUTPUT); //CH A – HIGH = forwards and LOW = backwards???
pinMode(6, OUTPUT); //CH B – HIGH = forwards and LOW = backwards???
//establish motor brake pins
pinMode(9, OUTPUT); //brake (disable) CH A
pinMode(8, OUTPUT); //brake (disable) CH B
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println(“WiFi shield not present”);
while(true); // don’t continue
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to Network named: ");
Serial.println(ssid); // print the network name (SSID);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
server.begin(); // start the web server on port 80
printWifiStatus(); // you’re connected now, so print out the status
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println(“new client”); // print a message out the serial port
String currentLine = “”; // make a String to hold incoming data from the client
String currentLine2 = “”;
String currentLine3 = “”;
String currentLine4 = “”;
String currentLine5 = “”;
while (client.connected()) { // loop while the client’s connected
if (client.available()) { // if there’s bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
if (c == ‘\n’) { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that’s the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what’s coming, then a blank line:
client.println(“HTTP/1.1 200 OK”);
client.println(“Content-type:text/html”);
client.println();
// the content of the HTTP response follows the header:
client.print(“Click <a href=”/H">here turn the LED on pin 4 on
client.print(“Click <a href=”/L”>here turn the LED on pin 4 off
client.print(“Click <a href=”/A”>here turn the LED on pin 5 on
client.print(“Click <a href=”/B”>here turn the LED on pin 5 off
client.print(“Click <a href=”/C”>here turn the LED on pin 6 on
client.print(“Click <a href=”/D”>here turn the LED on pin 6 off
client.print(“Click <a href=”/E”>here turn the LED on pin 2 on
client.print(“Click <a href=”/F”>here turn the LED on pin 2 off
client.print(“Click <a href=”/G”>here turn the Stepper
// The HTTP response ends with another blank line:
client.println();
// break out of the while loop:
else { // if you got a newline, then clear currentLine:
currentLine = “”;
currentLine2 = “”;
currentLine3 = “”;
currentLine4 = “”;
currentLine5 = “”;
else if (c != ‘\r’) { // if you got anything else but a carriage return character,
currentLine += c;
currentLine2 += c;
currentLine3 += c;
currentLine4 += c;
currentLine5 += c;
// Check to see if the client request was “GET /H” or “GET /L”:
if (currentLine.endsWith(“GET /H”)) {
digitalWrite(16, HIGH); // GET /H turns the LED on
if (currentLine.endsWith(“GET /L”)) {
digitalWrite(16, LOW); // GET /L turns the LED off
if (currentLine2.endsWith(“GET /A”)) {
digitalWrite(17, HIGH); // GET /A turns the LED on
if (currentLine2.endsWith(“GET /B”)) {
digitalWrite(17, LOW); // GET /B turns the LED off
if (currentLine3.endsWith(“GET /C”)) {
digitalWrite(18, HIGH); // GET /A turns the LED on
if (currentLine3.endsWith(“GET /D”)) {
digitalWrite(18, LOW); // GET /B turns the LED off
if (currentLine4.endsWith(“GET /E”)) {
digitalWrite(19, HIGH); // GET /A turns the LED on
if (currentLine4.endsWith(“GET /F”)) {
digitalWrite(19, LOW); // GET /B turns the LED off
if (currentLine5.endsWith(“GET /G”)) { //stepper motor
// for(int x; x < 500; x++) {
// state=digitalRead(0);
// if (state == LOW){
digitalWrite(9, LOW); //ENABLE CH A
digitalWrite(8, HIGH); //DISABLE CH B
digitalWrite(5, HIGH); //Sets direction of CH A
analogWrite(A0, 255); //Moves CH A
// else{
delay(delaylegnth);
digitalWrite(9, HIGH); //DISABLE CH A
digitalWrite(8, LOW); //ENABLE CH B
digitalWrite(6, LOW); //Sets direction of CH B
analogWrite(A1, 255); //Moves CH B
delay(delaylegnth);
digitalWrite(5, LOW); //Sets direction of CH A
delay(delaylegnth);
digitalWrite(6, HIGH); //Sets direction of CH B
delay(delaylegnth);
// close the connection:
client.stop();
Serial.println(“client disonnected”);
void printWifiStatus() {
// print the SSID of the network you’re attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield’s IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print(“signal strength (RSSI):”);
Serial.print(rssi);
Serial.println(" dBm");
// print where to go in a browser:
Serial.print(“To see this page in action, open a browser to http://”);
Serial.println(ip);
I am currently involved in a project which needs to have 4 led's and one stepper motor to be turned on/off independently over wifi.
The two shields are incompatible, at least on an UNO. The WiFi shield uses the SPI bus for the communication between the two processors while the motor shields uses pins 11, 12 and 13 to control the motor (D3, D8, D9, A0 and A1 too but that's not relevant in this case) but these pins are the SPI pins on the UNO. You either have to change to a Mega (the SPI pins are on 51, 52, 53) or a Leonardo (there they are available on the ICSP connector only) to be able to use the motor shield together with the WiFi shield.
