Wifi shield cannot connect to server.
Hallo,
I just bought a wifi shield. I have run some examples from the IDE ( arduino can connect to my wifi ), but when i try to connect (again with examples) with Google server (arduino is WifiWebClient), it cannot connect to server. What is the reason of this situation, anybody have the same problem? Also i want to ask how i can get the current firmware of my shield? Maybe this cause it?
Probably not. You may be using inappropriate code, or more likely your code does not a proper match your network setup.
Finally it was the IDE version which caused the problem. I downloaded v 1.0.2 and everything works fine.
I've the same problem. I will try your solution. From wich version of IDE you started (IDE that doesn't work)?
UPDATE: I've updated the firmware and all works fine!! (with IDE 1.0.5)
