Like the titel already explains, I have the WiFi shield and use it as a webserver for my tank. I use the Windows COM to make a GET request. I close the connection after it received the command, but that one step takes a whole second. How can I fasten this up?
Or better: How can I avoid to close the connection?
I didn't think it's necessary to post code, but here you go:
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "NerdtechCorporation"; // your network SSID (name)
char pass[] = "the password"; // your network password
char ssid2[]="Arduino Tank"; // My hotspot on my laptop to be able to control the tank everywhere
char pass2[]="wowmuchawesome"; // The password for that
WiFiServer server(3178);
int pin1=3; //LED for the transistor that controls the forward speed of the left motor
int pin2=5; //LED for the transistor that controls the backward speed of the left motor
int pin3=6; //Same like pin1 but for right
int pin4=9; //Same like pin2 but for right
int netz=0; // which network, 0-none, 1-homenetwork, 2-Arduino Tank (hotspot)
boolean go=false; // So it only starts to add chars when I already got a "G" because of "GET"
long time=0; // for timeout
int run=0; // I don't want to check the connection all the time
String relativex=""; //Left speed
String relativey=""; //Right speed (variable names stayed although I changed the way I control it, ignore)
String currentLine=""; //The current received line
int status = WL_IDLE_STATUS; // the Wifi radio's status
char floatbuf[64]; //For converting chars in flaot
float speedlinks=0.0; //speed left
float speedrechts=0.0; //speed right
pinMode(pin1, OUTPUT);
pinMode(pin2, OUTPUT); // I just see that I forgot to add the other two pins, how the hell could the work?!
tryconnect(); // first connection
if (run>60000) { // only test all 60 seconds
run=0; //sets the countdown back to 0
Serial.println("Run");
if (WiFi.status()!=WL_CONNECTED) { // and only if it's not connected
tryconnect(); //tries to connect
run+=1; //countup
delay(1);
webserver(); //checks for connection and tries to receive data
void tryconnect() { // works like a charm
Serial.println("Trying to connect.");
if (int num=WiFi.scanNetworks()>(-1)) {
for (int thisNet = 0; thisNet<num; thisNet++) {
if (WiFi.SSID(thisNet)=="NerdtechCorporation") {
netz=1;
} else if (WiFi.SSID(thisNet)=="Arduino Tank") {
netz=2;
netz=0;
Serial.println("Attempting to connect to Arduino Tank...");
if (netz==2) {
status = WiFi.begin(ssid2, pass2);
if ( status != WL_CONNECTED) {
Serial.println("Couldn't connect to Arduino Tank.");
Serial.println("Attempting to connect to NerdtechCorporation...");
if (netz=1) {
status = WiFi.begin(ssid, pass);
Serial.println("Couldn't connect to NerdtechCorporation.");
Serial.println("Connected to NerdtechCorporation.");
server.begin();
printWifiStatus();
Serial.println("Connected to Arduino Tank.");
server.begin();
printWifiStatus();
Serial.println("Already connected");
void webserver() {
WiFiClient client = server.available();
if (client) {
time=millis(); //stores the beginning time
Serial.println(time);
Serial.println(millis());
Serial.println("new client");
currentLine = "";
while (client.connected()) {
if (millis()-time>5000) { // if it took 5 seconds timeout so stop everything and go back to loop()
Serial.println("Timeout.");
client.flush();
client.stop();
return;
if (client.available()) {
char c = client.read(); // reads incoming stuff
if (c == '\n') {
if (currentLine.length() == 0) {
client.println();
client.println();
else {
currentLine = "";
Serial.println("Blanked current line");
else if (c != '\r') {
currentLine += c;
speedthing();
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
client.println("Banana");
Serial.println("Sent response");
client.flush();
client.stop();
delay(10);
Serial.println("Delay over");
return;
Serial.println("Going to stop client manually");
client.stop();
Serial.println("client disconnected");
void speedthing() {
if (currentLine.substring(0,5)=="GET /"&¤tLine.indexOf("HTTP")!=-1) { // if the beginning is "GET /" and it contains "HTTP", it also contains the speed of the motors
currentLine=currentLine.substring(5,currentLine.length()-1);
Serial.println(currentLine);
currentLine=currentLine.substring(0,currentLine.indexOf(" "));
relativex=(currentLine.substring(0,currentLine.indexOf("x")));
relativey=(currentLine.substring(currentLine.indexOf("x")+1,currentLine.length()));
Serial.println(relativex);
Serial.println(relativey);
relativex.toCharArray(floatbuf,sizeof(floatbuf));
speedlinks=atof(floatbuf)*255;
relativey.toCharArray(floatbuf,sizeof(floatbuf));
speedrechts=atof(floatbuf)*255;
Serial.println(speedlinks);
Serial.println(speedrechts);
if (speedrechts<0) { // if it's backwards, stop the forward transistor (or so) and start the backwards one
analogWrite(pin3,0);
analogWrite(pin4,speedrechts*(-1));
} else { //else stop the backwards one and start the forwards one
analogWrite(pin4,0);
analogWrite(pin3,speedrechts);
if (speedlinks<0) { //same for left
analogWrite(pin1,0);
analogWrite(pin2,speedlinks*(-1));
analogWrite(pin2,0);
analogWrite(pin1,speedlinks);
Serial.println("Finished speed thing");
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
// print where to go in a browser:
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
#include <SPI.h>
#include <WiFi.h>
char floatbuf[8]; //For converting chars in flaot
run+=1; //countup
delay(1);
netz=1;
netz=2;
else {
netz=0;
if (netz==2) {
if (netz=1) {
else {
server.begin();
printWifiStatus();
else {
server.begin();
printWifiStatus();
else {
void webserver() {
if (client) {
currentLine = "";
client.flush();
client.stop();
return;
if (c == '\n') {
client.println();
client.println();
else {
currentLine = "";
currentLine += c;
speedthing();
client.println();
client.flush();
client.stop();
delay(10);
return;
client.stop();
void speedthing() {
else {
Serial.println(ip);
Serial.print(rssi);
Serial.println(ip);
I use the delay so it runs it only 1ms, so my 60000 are 60 seconds. I just realized how dumb that is, the commands need time too...
