My setup is an Arduino Mega and a Raspberry Pi. connected via WiFi, I want to send some strings to and fro each other, so I used socket programming. I have a python script which is listening to the same port and awaiting to accept any connection but my Arduino just cannot connect and after 4 tries or so, it prints 'No Socket Available'. Anybody has any solutions to this? My WiFi Shield firmware is 1.1.0.
I've done a few troubleshoot testing but still to no avail. With the python script running on my Rpi, I connect my laptop to the same network, and entered 192.168.70.1:5143 and the script was able to detect the connection successfully, thus I do not think there is a problem on my Rpi side.
There is no error, but it just keeps returning False from client.connect which I don't understand why. Please helpppppp
Urgently need help on this. Thanks in advance!
Arduino Code
#include <SPI.h>
#include <SD.h>
#include <WiFi.h>
#include <WiFiUdp.h>
#define SD_CS 4
// For WiFi Shield
int status = WL_IDLE_STATUS;
char ssid[] = "lightstick"; // your network SSID (name)
char pass[] = "lightstick"; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key Index number (needed only for WEP)
unsigned int localPort = 5143; // local port to listen on
char packetBuffer[1750]; //buffer to hold incoming packet
char temp[7];
char ReplyBuffer[] = "ac"; // a string to send back
IPAddress my_ip(192, 168, 70, 7);
IPAddress remote_ip(192, 168, 70, 1);
WiFiUDP Udp;
WiFiClient client;
String recvData = "";
void setup(void) {
// ------------------------ WiFi Shield ---------------------------------
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
// while (true);
Serial.println("WiFi shield Detected!");
String fv = WiFi.firmwareVersion();
//WiFi.config(my_ip);
// attempt to connect to Wifi network:
if (status != WL_CONNECTED) {
Serial.print(F("Attempting to connect to SSID: "));
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
while (status != WL_CONNECTED) {
Serial.println("Attempting to connect again...");
delay(3000);
Serial.println(F("WiFi establish connection ended!"));
Serial.println(fv);
if ( fv != "1.1.0" )
Serial.println("Please upgrade the firmware");
boolean rpiConnected = false;
if (status == WL_CONNECTED) {
Serial.println(F("Connected to wifi\n"));
printWifiStatus();
// Connection to rPi
while (rpiConnected == false) {
Serial.println(F("Connecting to rPi..."));
Serial.println(remote_ip);
Serial.println(localPort);
rpiConnected = client.connect(remote_ip, 5143);
Serial.println(rpiConnected);
Serial.println(F("\tWaiting for delay"));
//client.flush();
//client.stop();
delay(3000);
Serial.println("Connected to Raspberry Pi");
sendData("Arduino Connected");
printWifiStatus();
Serial.println(F("Wifi connection FAILED!"));
Python Script
import thread
import time
import socket
from collections import deque
RPI_HOST = '192.168.70.1'
PORT_FOR_ARDUINO = 5143
def ipComm():
print "Waiting for Arduino"
print "Starting socket connection."
ip = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
print "Started! Setting socket option, reuse address"
ip.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
# ip.setsockopt(socket.SOL_SOCKET, socket.SO_BROADCAST, 1)
hostname = socket.gethostname()
print hostname
hostip = socket.gethostbyname_ex(hostname)
print hostip
print "Set! Starting socket binding"
ip.bind((RPI_HOST, PORT_FOR_ARDUINO))
print RPI_HOST
print PORT_FOR_ARDUINO
print "Binded! Starting socket listening"
ip.listen(5)
print "Listening...."
data, pcaddr = ip.accept()
print "Connected to Arduino", pcaddr
return data, pcaddr
