WiFi Shield Firmware version 1.1.0
Hi Folks,
My objective is to be able to communicate using Wifi Shield on UDP packets. I am unable to do so. Currently I am using Wifi Firmware version 1.0 that came with the shield. Upon googling, I found that I should have firmware version 1..1 to enable udp packets. How do I get the firmware?
I found firmware on the arduino's website. But, I can't download it? And does it solve UDP problem?
https://github.com/arduino/Arduino/tree/master/hardware/arduino/firmwares/wifishield
Thanks
Hani Abidi
You can find instructions for downloading and upgrading the WiFi Shield firmware, using Windows, on my website.
http://mssystems.emscom.net/helpdesk/knowledgebase.php?article=50
It will solve most connection problems except the server. The udp and tcp client should work ok for you. There are some bugs in the way sockets are allocated, but I have that part worked out. That is in the library code, not the firmware.
I am still chasing the bugs in the server library.
Good instruction page, Matt!
edit: If you want to see/correct the bugs in the wifi library, here are the ones I found:
This corrects a bug that depletes the sockets if the tcp client connection fails 4 times.
This corrects a bug that also depletes the sockets if you start and stop udp 4 times.
This corrects a bug in the way that listening protocols allocate sockets.
This corrects a bug that erroneously releases a socket that should still be reserved for a listening socket.
Thank you so much SurferTim and Matts-UK.
I am using Arduino Due. I wasn't aware that firmware versions for Wifi Shield are provided with the Arduino IDE download.
I was able to download the required software and upgrade the firmware.
I am able to communicate between two WiFi Shields over UDP and now can begin working on my project. I found the following hyperlink very useful as well:
Thanks Again !
Hani Abidi
