WiFi shield GPS coordinates to server
I have implemented this code to read GPS coordinates and send them to a server. The coordinates appear on the serial monitor, but the server does not receive anything. Could this be more of a server problem? Or a mistake in this code?
Do you have any recommendations as to where my problem is? I would appreciate all and any help suggestions. Thank you very much!
#include <SPI.h>
#include <WiFi.h>
#include <SoftwareSerial.h>
#include <TinyGPS.h>
int status = WL_IDLE_STATUS;
WiFiClient client;
char ssid[] = "MySSID";
char pass[] = "Mypassword";
//byte mac[] = {
//0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //Physical address
char serverName[] = "ips1.robertjromano.com";
TinyGPS gps;
SoftwareSerial ss(6, 3);
static void smartdelay(unsigned long ms);
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
WiFi.begin(ssid);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while(true);
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to open SSID: ");
Serial.println(ssid);
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
Serial.print("You're connected to the network");
printCurrentNet();
printWifiData();
Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
Serial.println("Sats HDOP Latitude Longitude Fix Date Time Date Alt Course Speed Card Distance Course Card Chars Sentences Checksum");
Serial.println(" (deg) (deg) Age Age (m) --- from GPS ---- ---- to London ---- RX RX Fail");
Serial.println("-------------------------------------------------------------------------------------------------------------------------------------");
ss.begin(4800);
delay(10000);
printCurrentNet();
void printWifiData() {
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
Serial.println(ip);
// print your MAC address:
byte mac[6];
WiFi.macAddress(mac);
Serial.print("MAC address: ");
Serial.print(mac[5],HEX);
Serial.print(":");
Serial.print(mac[4],HEX);
Serial.print(":");
Serial.print(mac[3],HEX);
Serial.print(":");
Serial.print(mac[2],HEX);
Serial.print(":");
Serial.print(mac[1],HEX);
Serial.print(":");
Serial.println(mac[0],HEX);
// print your subnet mask:
// IPAddress subnet = WiFi.subnetMask();
// Serial.print("NetMask: ");
// Serial.println(subnet);
// // print your gateway address:
// IPAddress gateway = WiFi.gatewayIP();
// Serial.print("Gateway: ");
// Serial.println(gateway);
void printCurrentNet() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
float flat,flon;
unsigned long age, date, time, chars = 0;
unsigned short sentences = 0, failed = 0;
static const double LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
gps.f_get_position(&flat, &flon, &age);
print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 10, 6);
print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 11, 6);
print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
print_date(gps);
print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 7, 2);
print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2);
print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0xFFFFFFFF : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? TinyGPS::GPS_INVALID_F_ANGLE : TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
Serial.print("SPOT: ");
Serial.print(flat);
client.print("GET /sendfromarduino1.php?");
client.print("&i=");
client.print(flat);
Serial.print(" DISTANCE: ");
Serial.print(flon);
client.print("&distance=");
client.print(flon);
client.println(" HTTP/1.1"); //
client.println("Host: ips1.robertjromano.com"); //
client.println( "Content-Type: application/x-www-form-urlencoded" );
// client.println("User-Agent: Arduino"); // ethernet related stuff
// client.println("Accept: text/html"); //
// client.println("Connection: close");
client.println(); //
gps.stats(&chars, &sentences, &failed);
print_int(chars, 0xFFFFFFFF, 6);
print_int(sentences, 0xFFFFFFFF, 10);
print_int(failed, 0xFFFFFFFF, 9);
smartdelay(1000);
client.stop();
unsigned long start = millis();
do
while (ss.available())
gps.encode(ss.read());
} while (millis() - start < ms);
if (val == invalid)
while (len-- > 1)
Serial.print('*');
Serial.print(' ');
Serial.print(val, prec);
int vi = abs((int)val);
int flen = prec + (val < 0.0 ? 2 : 1); // . and -
flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
for (int i=flen; i<len; ++i)
Serial.print(' ');
smartdelay(0);
char sz[32];
if (val == invalid)
strcpy(sz, "*******");
sprintf(sz, "%ld", val);
sz[len] = 0;
for (int i=strlen(sz); i<len; ++i)
sz = ' ';
  • if (len > 0)*
  • sz[len-1] = ' ';*
  • Serial.print(sz);*
  • smartdelay(0);*
  • int year;*
  • byte month, day, hour, minute, second, hundredths;*
  • unsigned long age;*
  • gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);*
  • if (age == TinyGPS::GPS_INVALID_AGE)*
    _ Serial.print("********** ******** ");_
  • else*
  • char sz[32];*
  • sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d ",*
  • month, day, year, hour, minute, second);*
  • print_int(age, TinyGPS::GPS_INVALID_AGE, 5);*
  • smartdelay(0);*
  • int slen = strlen(str);*
  • for (int i=0; i<len; ++i)*
    _ Serial.print(i<slen ? str : ' ');_
    * smartdelay(0);*
You send data to the server. The server sends a reply. You don't read the reply. Why not?
Thank you for your response. What type of reply should I be receiving from the server? A friend of mine set up the server so I can send the data. I'm not too familiar with servers.
You should invite your friend over then.
Forget about your code for a while. Look at the WiFi as client example. Change it to call your script on your server, with your (bogus) data. That example shows how to get (and show) the response from the server, which just might provide a clue for you (or us, at least).
Have you got a program sitting waiting for this data on the server?
