wifi shield not present!!
Hey guys!
I am in trouble with connecting a wifi shield(CC3000, which doesn’t have a usb port, that is, only can be used by connecting with the Arduino) with Arduino R3. (You can see the pictures of them.)
After I connected it with the Arduino perfectly, I tried a few source codes such as driver patch 1_11 and buildtest from adafruit CC 3000 library.
But it said that ‘initializing CC3000…’ from both ‘buildtest’ and ‘driver patch’. And nothing happened.
I included ‘buildtest’ FYI.
Any thoughts?
Thank you for your help in advance!
p.s. I tried to install a firmware to the wifi shield, but I couldn’t do that for it said that ‘wifi shield not present’. Moreover, CC3000 doesn’t have a usb port as well. This is my second problem…
Here’s ‘buildtest’ source code.
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ   3  // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
                                         SPI_CLOCK_DIVIDER); // you can change this clock speed but DI
#define WLAN_SSID       "myNetwork"        // cannot be longer than 32 characters!
#define WLAN_PASS       "myPassword"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY   WLAN_SEC_WPA2
void setup(void)
  Serial.println(F("Hello, CC3000!\n"));
  displayDriverMode();
  Serial.print("Free RAM: "); Serial.println(getFreeRam(), DEC);
  /* Initialise the module */
  Serial.println(F("\nInitialising the CC3000 ..."));
  if (!cc3000.begin())
    Serial.println(F("Unable to initialise the CC3000! Check your wiring?"));
    while(1);
  /* Optional: Update the Mac Address to a known value */
  uint8_t macAddress[6] = { 0x08, 0x00, 0x28, 0x01, 0x79, 0xB7 };
   if (!cc3000.setMacAddress(macAddress))
     Serial.println(F("Failed trying to update the MAC address"));
     while(1);
  uint16_t firmware = checkFirmwareVersion();
  if (firmware < 0x113) {
    Serial.println(F("Wrong firmware version!"));
    for(;;);
  displayMACAddress();
  /* Optional: Get the SSID list (not available in 'tiny' mode) */
#ifndef CC3000_TINY_DRIVER
  listSSIDResults();
#endif
  /* Delete any old connection data on the module */
  Serial.println(F("\nDeleting old connection profiles"));
  if (!cc3000.deleteProfiles()) {
    Serial.println(F("Failed!"));
    while(1);
  /* Attempt to connect to an access point */
  char *ssid = WLAN_SSID;             /* Max 32 chars */
  Serial.print(F("\nAttempting to connect to ")); Serial.println(ssid);
  if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
    while(1);
  Serial.println(F("Connected!"));
  /* Wait for DHCP to complete */
  Serial.println(F("Request DHCP"));
  while (!cc3000.checkDHCP())
    delay(100); // ToDo: Insert a DHCP timeout!
  /* Display the IP address DNS, Gateway, etc. */
  while (! displayConnectionDetails()) {
  /* Try looking up www.adafruit.com */
  uint32_t ip = 0;
  Serial.print(F("www.adafruit.com -> "));
  while  (ip  ==  0)  {
    if  (!  cc3000.getHostByName("www.adafruit.com", &ip))  {
      Serial.println(F("Couldn't resolve!"));
  cc3000.printIPdotsRev(ip);
  /* Do a quick ping test on adafruit.com */
  Serial.print(F("\n\rPinging ")); cc3000.printIPdotsRev(ip); Serial.print("...");
  uint8_t replies = cc3000.ping(ip, 5);
  Serial.print(replies); Serial.println(F(" replies"));
  if (replies)
    Serial.println(F("Ping successful!"));
#endif
  Serial.println(F("\n\nClosing the connection"));
  cc3000.disconnect();
void loop(void)
void displayDriverMode(void)
  #ifdef CC3000_TINY_DRIVER
    Serial.println(F("CC3000 is configure in 'Tiny' mode"));
  #else
    Serial.print(F("RX Buffer : "));
    Serial.print(CC3000_RX_BUFFER_SIZE);
    Serial.println(F(" bytes"));
    Serial.print(F("TX Buffer : "));
    Serial.print(CC3000_TX_BUFFER_SIZE);
  #endif
uint16_t checkFirmwareVersion(void)
  uint8_t major, minor;
  uint16_t version;
  if(!cc3000.getFirmwareVersion(&major, &minor))
    Serial.println(F("Unable to retrieve the firmware version!\r\n"));
    version = 0;
    Serial.print(F("Firmware V. : "));
    Serial.print(major); Serial.print(F(".")); Serial.println(minor);
    version = major; version <<= 8; version |= minor;
#endif
  return version;
void displayMACAddress(void)
  uint8_t macAddress[6];
  if(!cc3000.getMacAddress(macAddress))
    Serial.println(F("Unable to retrieve MAC Address!\r\n"));
    Serial.print(F("MAC Address : "));
    cc3000.printHex((byte*)&macAddress, 6);
    @brief  Tries to read the IP address and other connection details
bool displayConnectionDetails(void)
  uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
  if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
    Serial.println(F("Unable to retrieve the IP Address!\r\n"));
    return false;
    Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
    Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
    Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
    Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
    Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
    return true;
void listSSIDResults(void)
  uint32_t index;
  uint8_t valid, rssi, sec;
  char ssidname[33];
  if (!cc3000.startSSIDscan(&index)) {
    Serial.println(F("SSID scan failed!"));
    return;
  Serial.print(F("Networks found: ")); Serial.println(index);
  Serial.println(F("================================================"));
  while (index) {
    index--;
    valid = cc3000.getNextSSID(&rssi, &sec, ssidname);
    Serial.print(F("SSID Name    : ")); Serial.print(ssidname);
    Serial.print(F("RSSI         : "));
    Serial.println(rssi);
    Serial.print(F("Security Mode: "));
    Serial.println(sec);
  cc3000.stopSSIDscan();
Do not double post.
