- What is the maximum current usage on the WIFI-shield?
- Can i use it in Ad-hoc or Wifi-direct/p2p mode? I need to connect it to a PC without a Wireless-router.
- Can i attach an external antenna to it?
27 Giga-amps. You are talking about the Back-to-the-future-wifi-shield, right? If not, you might clarify.
See previous comment.
Do you see a place to? See previous comment.
What kind of answer was that?
What do you want me to clarify??
I'm talking about the Arduino WIFI-Shield R3.
I need to know the approx current-usage in order to choose the right type of battery for my setup.
Also, i need to use an external antenna, if possible.
I want to connect the Shield to the PC, without the use of an Router, in adhoc mode.
Is it clear enough now?
- Not sure about maximal amperage. No documentation. I have no means to measure that or worry about it in my projects.
- Not sure. There is no documentation on the shield's capability for those connection modes.
- Not sure. There seems to be no antenna connector. Do you see one on the photos?
PaulS is kidding, he is a expert about Arduino and help a lot of members at forum.
WIFI-shield has two big power hungry devices;
HDG104 WIFI chip
Current - Receiving 60mA
Current - Transmitting 15mA
AT32UC3A 32 bits CPU
Current - 37mA
maximum current usage on the WIFI-shield is ~100mA (at least).
I doubt it support Ad-hoc or Wifi-direct/p2p mode. Here is the link of firmware;-
at least from diagram it support.
I am not sure about my answer, if I were you , I will drop a line to Arduino team to ask support.
WIFI-shield might not be good candidate for this type application. by select right type of battery and wireless solution your system could last years, said 10 years.
That's what I wanted you to clarify. There are a lot of WiFi shields. Answers about the current requirement of my WiFi shield won't mean a thing unless you have the same shield. Your's was a mystery, so the answer I gave was guaranteed to be high enough to cover your shield (by a fair margin).
