Hi everyone,
I am new in Arduino. I have an arduino UNO and a Wifi Shield V2.0 from Seeed Studio.
I have piled the shield to the arduino and that's all.
Now, i try to upload the following code to my adruino :
#include <SoftwareSerial.h>
#include "WiFly.h"
SoftwareSerial uart(0, 1); // create a serial connection to the WiFi shield TX and RX pins.
WiFly wifly(&uart); // create a WiFly library object using the serial connection to the WiFi shield we created above.
uart.begin(9600); // start the serial connection to the shield
Serial.begin(9600); // start the Arduino serial monitor window connection
wifly.reset(); // reset the shield
while(wifly.join("BoxName","Password",WIFLY_AUTH_WPA2_PSK) == false)
Serial.println("Failed to connect to accesspoint. Will try again.");
Serial.println("Connected to access point!");
I get the following error message :
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf2
The parameters i have are the following one :
Card name : Duemilanove Diacimila
Processor : AT mega 328 P
Progammer : Arduino Gemma
I have checked the port is well connected to COM3
I don't know where the problem may come from, have you met such problem ?
Thank you for your help !
