wifi shield static ip
hello everyone ,
this is the first post here and i hope i found a solution for my problem which is :
i have a wifi shield " old firmware" and when i use example of " wifiWebServer" in serial shows me that it is connected and gives me the ip but when i open the page gives me " not found" in all browsers .
then i found out that i have to downgrade my arduino IDE to 1.0.2 and it works great … but there is no “wifi.config()” method in the old version library to set a static ip for my wifi shield now
i just wanna a method in the old library that can do same action or to solve the problem of " not found page" in the latest version 1.0.6 and then use the config() method …
i will be so grateful if you could help me
:slight_smile:
If you want to use the config function, you must upgrade the wifi firmware. After you upgrade, then you must use an IDE version v1.0.4 or later.
