WiFi shield Streaming Video/Image upload to server
I'm doing a project for my master thesis.
It would be great if I could add features like streaming video to a server using arduino due and wifi shield.
Is that technically possible with arduino or i should find a different solution.
Also, if transmitting a video is too much I'm satisfied with uploading a jpeg from the camera to a web server every second.
If that's possible which camera do you recommend for that purpose.
Thank you in advance!
Mirza
Then do some math and see what data rate you need for this.
Then look at the 16MHz clock on the Arduino processor.
Again work out the data rate you require.
You can answer that question yourself when you know the data rate.
