Wifi shield upgrade, no device present
Hi forum!
I'm using an Uno and an Arduino wifi shield, after upgrading, though, the shield is no longer present:
(WiFi.status() == WL_NO_SHIELD) {
And looking back in terminal:
dfu-programmer: no device present.
I have tried jumping pins 3 and 7, with no luck.
I followed the instructions here:
And used this library:
After you flash the first file, you may need to unplug the USB cable from your computer and plug it back in, then flash the second file. Hopefully that works, I can tell you that if you have a problem with wifi firmware, you will never get a response on these forums, and arduino email support is even worse. My wifi shield is screwed up and I haven't been able to get even a reasonably helpful response in 3 months.
I upgraded with only minor problems, and most was related to the command line program not finding the firmware. I used the firmware included with IDE v1.0.5, and it did ok. This post is how I solved my problem.
http://forum.arduino.cc/index.php?topic=216104.msg1580246#msg1580246
