WiFi Shield V2.2 WizFi210
I have problems with the setting comunication on wifi Shield WizFi210.
( http://www.robot-domestici.it/joomla/component/virtuemart/Arduino/arduino-shield/wifi-shield-v22-for-arduino ).
I use IDE of Arduino e when type the "at" command the answer are only ascii words.
I use shileld with this setting:
Usb on Shield ( On ) and Run.
both LF+CR anche 115200 baud in software setting.
In Putty software i have same problem.
Can you help me please?
Thank you. :frowning:
This is what I would expect the device to do. What did you expect?
This a screenshot of the answer.
This is no a correct message.
Eureka! I find the solution.
Before need load "blink" sketch on arduino because other sketch send information on port COM.
Thank you. ]:slight_smile:
