Wifi Shield web server Example help [solved]
Hi guys,
So Im playing around with the arduino wifi shield. I uploaded the wifi web server LED Blink example. it compiles fine, and runs fine on the serial monitor. so when the serial monitor says "To see this page in action, open a browser to http://172.20.10.4". i simply copy paste the http://172.20.10.4 to my web browser, right? cause when i do that nothing happens. First i thought it could be that the firmware on the wifi shield was 1.0.0. so i upgraded it to 1.1.0. but same thing. what am i not understanding and/or doing wrong? please any help would be greatly appreciated. thank you.
  WiFi Web Server LED Blink
 A simple web server that lets you blink an LED via the web.
 This sketch will print the IP address of your WiFi Shield (once connected)
 to the Serial monitor. From there, you can open that address in a web browser
 to turn on and off the LED on pin 9.
 If the IP address of your shield is yourAddress:
 http://yourAddress/H turns the LED on
 http://yourAddress/L turns it off
 This example is written for a network using WPA encryption. For
 WEP or WPA, change the Wifi.begin() call accordingly.
 Circuit:
 * WiFi shield attached
 * LED attached to pin 9
 created 25 Nov 2012
 by Tom Igoe
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "iPhone SN";      //  your network SSID (name)
char pass[] = "1234567890";   // your network password
int keyIndex = 0;                 // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
  Serial.begin(9600);      // initialize serial communication
  pinMode(9, OUTPUT);      // set the LED pin mode
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    while(true);        // don't continue
  // attempt to connect to Wifi network:
  while ( status != WL_CONNECTED) {
    Serial.print(F("Firmware version: "));
    Serial.println(WiFi.firmwareVersion());
    Serial.print("Attempting to connect to Network named: ");
    Serial.println(ssid);                   // print the network name (SSID);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  server.begin();                           // start the web server on port 80
  printWifiStatus();                        // you're connected now, so print out the status
  WiFiClient client = server.available();   // listen for incoming clients
  if (client) {                             // if you get a client,
    Serial.println("new client");           // print a message out the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected()) {            // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("Content-type:text/html");
            client.println();
            // the content of the HTTP response follows the header:
            client.print("Click <a href=\"/H\">here</a> turn the LED on pin 9 on
            client.print("Click <a href=\"/L\">here</a> turn the LED on pin 9 off
            // The HTTP response ends with another blank line:
            client.println();
            // break out of the while loop:
          else {      // if you got a newline, then clear currentLine:
            currentLine = "";
        else if (c != '\r') {    // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
        // Check to see if the client request was "GET /H" or "GET /L":
        if (currentLine.endsWith("GET /H")) {
          digitalWrite(9, HIGH);               // GET /H turns the LED on
        if (currentLine.endsWith("GET /L")) {
          digitalWrite(9, LOW);                // GET /L turns the LED off
    // close the connection:
    client.stop();
    Serial.println("client disonnected");
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
  // print where to go in a browser:
  Serial.print("To see this page in action, open a browser to http://");
  Serial.println(ip);
and the serial monitor shows:
Firmware version: 1.1.0
Attempting to connect to Network named: iPhone SN
SSID: iPhone SN
IP Address: 172.20.10.4
signal strength (RSSI):-29 dBm
I tried the code you posted, changing the ssid and passphrase, and it is working ok here.
Are you using a computer on the same localnet or router as the WiFi shield?
its works fine now. I don't know what the problem was. thank you.
cheers,
p.s how do i mark a post as solved?
You mark it as solved by going back to your original post and edit the subject line to add [solved].
