Guten Abend
Ich betreibe das Wifi Shield (bereits firmwareupdate) hinter einer Fritzbox. Die Verbindung klappt. Ich möchte per UDP und NTP einen Zeitserver anrufen bekomme aber nur ein paket “Null” zurück.
hier der Code:
#include <SPI.h>
#include <WiFi.h>
#include <WiFiUdp.h>
int status = WL_IDLE_STATUS;
char ssid[] = "FRITZ!7390"; // your network SSID (name)
char pass[] = "xxxxxxxxxxxx"; // your network password
int keyIndex = 0; // your network key Index number (needed only for WEP)
unsigned int localPort = 8888; // local port to listen for UDP packets
IPAddress timeServer(165, 193, 126, 229); // 129, 143, 2, 23 time.nist.gov NTP server
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
WiFiUDP Udp; // A UDP instance to let us send and receive packets over UDP
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
String fv = WiFi.firmwareVersion();
Serial.println(WiFi.firmwareVersion());
if ( fv != "1.1.0" )
Serial.println("Please upgrade the firmware");
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while (true);
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
Serial.println("Connected to wifi");
printWifiStatus();
Serial.println("\nStarting connection to server...");
Udp.begin(localPort);
Serial.println("Los...");
sendNTPpacket(timeServer); // send an NTP packet to a time server
// wait to see if a reply is available
delay(10000);
Serial.println( Udp.parsePacket() );
if ( Udp.parsePacket() ) {
Serial.println("packet received");
// We've received a packet, read the data from it
Udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
//the timestamp starts at byte 40 of the received packet and is four bytes,
// or two words, long. First, esxtract the two words:
unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
// combine the four bytes (two words) into a long integer
// this is NTP time (seconds since Jan 1 1900):
unsigned long secsSince1900 = highWord << 16 | lowWord;
Serial.print("Seconds since Jan 1 1900 = " );
Serial.println(secsSince1900);
// now convert NTP time into everyday time:
Serial.print("Unix time = ");
// Unix time starts on Jan 1 1970. In seconds, that's 2208988800:
const unsigned long seventyYears = 2208988800UL;
// subtract seventy years:
unsigned long epoch = secsSince1900 - seventyYears;
// print Unix time:
Serial.println(epoch);
// print the hour, minute and second:
Serial.print("The UTC time is "); // UTC is the time at Greenwich Meridian (GMT)
Serial.print((epoch % 86400L) / 3600); // print the hour (86400 equals secs per day)
Serial.print(':');
if ( ((epoch % 3600) / 60) < 10 ) {
// In the first 10 minutes of each hour, we'll want a leading '0'
Serial.print('0');
Serial.print((epoch % 3600) / 60); // print the minute (3600 equals secs per minute)
Serial.print(':');
if ( (epoch % 60) < 10 ) {
// In the first 10 seconds of each minute, we'll want a leading '0'
Serial.print('0');
Serial.println(epoch % 60); // print the second
// wait ten seconds before asking for the time again
delay(10000);
// send an NTP request to the time server at the given address
unsigned long sendNTPpacket(IPAddress& address)
//Serial.println(address);
// set all bytes in the buffer to 0
memset(packetBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
//Serial.println("2");
packetBuffer[0] = 0b11100011; // LI, Version, Mode
packetBuffer[1] = 0; // Stratum, or type of clock
packetBuffer[2] = 6; // Polling Interval
packetBuffer[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
//Serial.println("3");
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
Udp.beginPacket(address, 123); //NTP requests are to port 123
//Serial.println("4");
Udp.write(packetBuffer, NTP_PACKET_SIZE);
//Serial.println("5");
Udp.endPacket();
//Serial.println("6");
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
Der Zeitserver lebt aber. Dh mit einem NTP toll gibt er Antwort.
Warum erhält dann der UNO per WIFI nur NULL? DAnke für jeden Hinweis.
Combo
