Hello everyone,
i’m working on a car with 2 wheels that should work with l293d motor driver and a wifi shield .
When I put my code in arduino I’m successfully connected to my mobile hotspot and I can ping my arduino with my computer in the same network .
I really need your help guys , it’s my diploma work and Im strugging on it since 3 weeks and even the teacher didn’t understand why It didn’t worked.
The problem is when I go the link of the IP adress of my arduino I have a connection refused . Here is the code :
#include <SPI.h>
#include <WiFi.h>
#define E1 2 // Enable Pin for motor 1
#define E2 3 // Enable Pin for motor 2
#define I1 5 // Control pin 1 for motor 1
#define I2 6 // Control pin 2 for motor 1
#define I3 8 // Control pin 1 for motor 2
#define I4 9 // Control pin 2 for motor 2
char ssid[] = "Bicraveur de connexion"; // your network SSID (name)
char pass[] = "yousslebg"; // your network password
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
Serial.begin(9600); // initialize serial communication
//pinMode(9, OUTPUT); // set the LED pin mode
pinMode(E1, OUTPUT);
pinMode(E2, OUTPUT);
pinMode(I1, OUTPUT);
pinMode(I2, OUTPUT);
pinMode(I3, OUTPUT);
pinMode(I4, OUTPUT);
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
while (true); // don't continue
WiFiServer server(80);
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
server.begin();
// you're connected now, so print out the status:
printWifiStatus();
// listen for incoming clients
WiFiClient client = server.available();
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
Serial.println(currentLine.length());
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println();
// the content of the HTTP response follows the header:
//client.print("Click <a href=\"/H\">here</a> turn the LED on pin 9 on
//client.print("Click <a href=\"/L\">here</a> turn the LED on pin 9 off
client.print("Click <a href=\"/F\">Forward</a> to move the robot Forward
//client.print("Click <a href=\"/R\">Right</a> to move the robot Right
//client.print("Click <a href=\"/L\">Left</a> to move the robot Left
//client.print("Click <a href=\"/B\">Backwards</a> to move the robot Backward
//client.print("Click <a href=\"/S\">Stop</a> to stop the robot
// The HTTP response ends with another blank line:
client.println();
// break out of the while loop:
else { // if you got a newline, then clear currentLine:
currentLine = "";
else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
//w Check to see if the client request was "GET /H" or "GET /L":
if (currentLine.endsWith("GET /H")) {
digitalWrite(9, HIGH); // GET /H turns the LED on
if (currentLine.endsWith("GET /L")) {
digitalWrite(9, LOW); // GET /L turns the LED off
if (currentLine.endsWith("GET /F")) {
digitalWrite(E1, HIGH); // GET /F moves forward
digitalWrite(E2, HIGH);
digitalWrite(I1, HIGH);
digitalWrite(I2, LOW);
digitalWrite(I3, HIGH);
digitalWrite(I4, LOW);
if (currentLine.endsWith("GET /R")) {
digitalWrite(E1, LOW);
digitalWrite(E2, LOW);
//delay(2000);
digitalWrite(I1, LOW);
digitalWrite(I3, LOW);
digitalWrite(I4, HIGH);
//delay(2000);
if (currentLine.endsWith("GET /B")) {
//delay(2000);
digitalWrite(I2, HIGH);
if (currentLine.endsWith("GET /S")) {
// close the connection:
client.stop();
Serial.println("client disonnected");
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
// print where to go in a browser:
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
