Wifi wont connect - ESP32 itsybitsy - Bad Board?
I am trying to set up a adafruit_itsybitsy_esp32 (Overview | Adafruit ItsyBitsy ESP32 | Adafruit Learning System) but I can not get it to connect to wifi. When I scan with it it sees the wifi networks so it looks like the wifi module is working. When I run a similar sketch on other boards (adafruit feather esp32 s3 reverse tft) it connects fine. I even set up an open SSID and it still won't connect.
On password protected SSIDs it was kicking out status 6, on the open SSID it kicked out status 4.
Any ideas?
trial wifi code below:
// Adafruit ItsyBitsy ESP32 Wi-Fi
#include <Arduino.h>
#include <WiFi.h>
// Wi-Fi credentials
const char* ssid = "iceshots24";
const char* password = "";
  // Initialize serial communication
  delay(5000);
  Serial.println("\nStarting Wi-Fi Scanner...");
  // Set Wi-Fi to station mode
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  delay(100);
  Serial.println("Scanning for Wi-Fi networks...");
int n = WiFi.scanNetworks();
  Serial.printf("Found %d networks:\n", n);
  for (int i = 0; i < n; ++i) {
    // Print SSID, RSSI, and encryption type
    Serial.printf("%d: %s (%d dBm) %s\n", i + 1, WiFi.SSID(i).c_str(), WiFi.RSSI(i),
                  (WiFi.encryptionType(i) == WIFI_AUTH_OPEN) ? "Open" : "Secured");
  Serial.println("\nScan complete. Scanning again in 5 seconds...");
  delay(5000); // Delay 5 seconds before scanning again
  // Connect to Wi-Fi
  Serial.print("Connecting to Wi-Fi---");
  Serial.print(ssid);
  Serial.print("||");
  Serial.println(password);
  WiFi.disconnect(true); // Clear previous Wi-Fi connections
  WiFi.mode(WIFI_STA);   // Ensure station mode
  WiFi.begin(ssid, password);
  int attempts = 0;
  while (WiFi.status() != WL_CONNECTED && attempts < 20) { // Attempt for 20 seconds
    delay(2000); // Extended delay for stability
    attempts++;
    Serial.print("Attempt ");
    Serial.print(attempts);
    Serial.print(": Status = ");
    Serial.println(WiFi.status());
    // Display connection status
    switch (WiFi.status()) {
      case WL_NO_SSID_AVAIL:
        Serial.println("ERROR: SSID not available.");
      case WL_CONNECT_FAILED:
        Serial.println("ERROR: Connection failed. Check password.");
      case WL_DISCONNECTED:
        Serial.println("ERROR: Disconnected from Wi-Fi.");
      default:
        Serial.println("Attempting to connect...");
  if (WiFi.status() == WL_CONNECTED) {
    Serial.println("\nWi-Fi connected!");
    Serial.print("IP Address: ");
    Serial.println("\nFailed to connect to Wi-Fi after 20 attempts.");
    return;
Serial printout:
Found 11 networks:
1: iceshots24 (-62 dBm) Open
2: iceshots2 (-63 dBm) Secured
3: iceshots-good (-67 dBm) Secured
4: NETGEAR19 (-83 dBm) Secured
5: ORBI62 (-83 dBm) Secured
6: yurowifi (-87 dBm) Secured
7: ATT136 (-87 dBm) Secured
8: Pineapple Xfinity (-91 dBm) Secured
9: iceshots-good (-92 dBm) Secured
10: HT-A5000.l066, (-92 dBm) Open
11: Pineapple Mesh (-93 dBm) Secured
Connecting to Wi-Fi---iceshots24||
Attempt 1: Status = 4
Attempt 2: Status = 4
Attempt 3: Status = 4
Attempt 4: Status = 4
Attempt 5: Status = 4
Attempt 6: Status = 4
Attempt 7: Status = 4
Attempt 8: Status = 4
Attempt 9: Status = 4
Attempt 10: Status = 4
Attempt 11: Status = 4
Attempt 12: Status = 4
Attempt 13: Status = 4
to make it even more strange, if I enter a password for the open SSID, I get status 6, then status 1s:
modified code:
const char* password = "123";
serial:
Connecting to Wi-Fi---iceshots24||123
Attempt 1: Status = 6
Attempt 2: Status = 1
Attempt 3: Status = 1
Attempt 4: Status = 1
When I try to connect to a protected SSID with correct credentials I get Status 6s:
Connecting to Wi-Fi---iceshots-good||##Password##
Attempt 2: Status = 6
Attempt 3: Status = 6
Attempt 4: Status = 6
Attempt 5: Status = 6
Are you sure the password of the router is NULL, or perhaps blank(s). Try using a password and see if it works (it should) then your issue is your code is "" which is what in ascii and the router is ??? Bet they are different.
Since we can't see what password or ssid you entered in the router, it's hard to know what is wrong.
It is null, when I connect with a different board it doesn't matter if there is a password entered or not. As it is a open network it connects either way. You can see it is an open network and the SSID is correct from the wifi scan.
In my previous reply I show what happens when a password is used on the open network as well as if the correct password is used on a protected network.
I can run the same code on a different board (adafruit feather esp32 s3 reverse tft) and it works fine.
Ok, do it your way, good luck.
Sorry, didn't mean to force my way. Just trying to update you guys with as much info as I had.
I did manage to fix the issue for anyone with similar problems. It appears the Wifi module on this smaller board is a bit more temperamental and I needed to give it more time and sometimes several tries to connect.
Thanks @sonofcy for the help
Matt
