Wifi Yun trouble
Hi everybody !
I encounter some problems to connect my Arduino Yun on my wifi... :frowning:
I'm on the IDE 1.5.5. I follow the guide to the Arduino Yun to connect my board on Internet.
But it seems that my board could not connect to my wifi. My router is at 1 meter from my board.
The SSID and the password are OK. My computer and my iPhone are connected. The signal strength is high.
I uploaded the wifi statut sketch : http://arduino.cc/en/Tutorial/YunWiFiStatus
Sometimes the signal is at 0% and sometimes the signal is at 37%.
I also uploaded this sketch : is it possible to control the wifi led? Any command? - Arduino Yún - Arduino Forum
Sometimes my blue led blinks and I can access to the arduino.local page (so my board is connected to my network) but most of the time the blue led is off and I couldn't access to the arduino.local page (so my board is not conencted).
I pressed the WLAN RST button, but the problem was not solved.
Could you help me ?
Many thanks,
Alexander
Does the yun reboot itself after 60 seconds after you've configured its wifi?
Yes.
I have the message : "Configuration saved ! I'm restarting. Please connect your computer to the wireless network called MyWifi" (MyWifi is my home's wifi).
Then, I connect my computer to my network MyWifi, and I couldn't access to my board on the page "arduino.local".
Sometimes the board is connected to my network during 5 minutes, sometimes during 10 minutes, and I could access to my board on the page arduino.local. But most of the time the card is not connected.
I see it with the "blue led sketch" or "wifi status sketch".
Thanks for your help Frederico.
Please can you
  • upload the YunSerialTerminal right after having configured wifi
  • open the serial monitor (the yun is connected via usb cable)
  • watch linux booting
  • wait a couple of minutes (until you lose connection with the yun)
  • finally copy and paste the displayed text here
Hi Federico,
Thanks for your help. Here is the reponse on the serial monitor :
[  123.150000] wlan0: authenticate with 00:25:15:b6:b2:68
[  123.180000] wlan0: send auth to 00:25:15:b6:b2:68 (try 1/3)
[  123.250000] wlan0: send auth to 00:25:15:b6:b2:68 (try 2/3)
[  123.310000] wlan0: send auth to 00:25:15:b6:b2:68 (try 3/3)
[  123.340000] wlan0: authentication with 00:25:15:b6:b2:68 timed out
[  134.320000] wlan0: authenticate with 00:25:15:b6:b2:68
[  134.350000] wlan0: send auth to 00:25:15:b6:b2:68 (try 1/3)
[  134.380000] wlan0: send auth to 00:25:15:b6:b2:68 (try 2/3)
[  134.380000] wlan0: authenticated
[  134.390000] wlan0: associate with 00:25:15:b6:b2:68 (try 1/3)
[  134.470000] wlan0: associate with 00:25:15:b6:b2:68 (try 2/3)
[  134.510000] wlan0: associate with 00:25:15:b6:b2:68 (try 3/3)
[  134.520000] wlan0: RX AssocResp from 00:25:15:b6:b2:68 (capab=0x411 status=0 aid=5)
[  134.520000] wlan0: associated
[  167.120000] wlan0: authenticate with 00:25:15:b6:b2:68
[  167.150000] wlan0: send auth to 00:25:15:b6:b2:68 (try 1/3)
[  167.190000] wlan0: authenticated
[  167.210000] wlan0: associate with 00:25:15:b6:b2:68 (try 1/3)
[  167.210000] wlan0: RX AssocResp from 00:25:15:b6:b2:68 (capab=0x411 status=0 aid=5)
[  167.210000] wlan0: associated
[  360.600000] wlan0: authenticate with 00:25:15:b6:b2:68
[  360.630000] wlan0: direct probe to 00:25:15:b6:b2:68 (try 1/3)
[  360.740000] wlan0: direct probe to 00:25:15:b6:b2:68 (try 2/3)
[  360.850000] wlan0: direct probe to 00:25:15:b6:b2:68 (try 3/3)
[  360.960000] wlan0: authentication with 00:25:15:b6:b2:68 timed out
[  364.400000] wlan0: authenticate with 00:25:15:b6:b2:68
[  364.430000] wlan0: send auth to 00:25:15:b6:b2:68 (try 1/3)
[  364.500000] wlan0: send auth to 00:25:15:b6:b2:68 (try 2/3)
[  364.580000] wlan0: send auth to 00:25:15:b6:b2:68 (try 3/3)
[  364.640000] wlan0: authentication with 00:25:15:b6:b2:68 timed out
[  368.580000] wlan0: authenticate with 00:25:15:b6:b2:68
[  368.610000] wlan0: send auth to 00:25:15:b6:b2:68 (try 1/3)
[  368.640000] wlan0: send auth to 00:25:15:b6:b2:68 (try 2/3)
[  368.680000] wlan0: send auth to 00:25:15:b6:b2:68 (try 3/3)
[  368.740000] wlan0: authentication with 00:25:15:b6:b2:68 timed out
[  376.690000] wlan0: authenticate with 00:25:15:b6:b2:68
[  376.720000] wlan0: send auth to 00:25:15:b6:b2:68 (try 1/3)
[  376.770000] wlan0: send auth to 00:25:15:b6:b2:68 (try 2/3)
[  376.840000] wlan0: send auth to 00:25:15:b6:b2:68 (try 3/3)
[  376.890000] wlan0: authentication with 00:25:15:b6:b2:68 timed out
[  387.860000] wlan0: authenticate with 00:25:15:b6:b2:68
[  387.890000] wlan0: send auth to 00:25:15:b6:b2:68 (try 1/3)
[  387.950000] wlan0: send auth to 00:25:15:b6:b2:68 (try 2/3)
[  388.020000] wlan0: send auth to 00:25:15:b6:b2:68 (try 3/3)
[  388.090000] wlan0: authentication with 00:25:15:b6:b2:68 timed out
[  399.070000] wlan0: authenticate with 00:25:15:b6:b2:68
[  399.100000] wlan0: send auth to 00:25:15:b6:b2:68 (try 1/3)
[  399.160000] wlan0: send auth to 00:25:15:b6:b2:68 (try 2/3)
[  399.220000] wlan0: send auth to 00:25:15:b6:b2:68 (try 3/3)
[  399.270000] wlan0: authentication with 00:25:15:b6:b2:68 timed out
Any ideas ?
I try so many things, I don't know how to solve it.
Tonight I'm gonna test my board on other wifi (friends / family)... and keep you informed :slight_smile:
I run at linino console root@Arduino:~#/usr/bin/pretty-wifi-info.lua
Current WiFi configuration
SSID: My_Wireless_Router
Mode: Client
Signal: 100%
Encryption method: WPA PSK (CCMP)
Interface name: wlan0
Active for: 37 minutes
IP address: 192.168.0.109/255.255.255.0
MAC address: 90:A2:DA:F0:06:76
RX/TX: 1142/177 KBs
Signal: 100%
To find out best Channel to use you could use android phone/pad by play store download Application wifi Analyzer.
from above the Channel 4 is best bet. (Ensure you select a correct country to conform local law. Incorrect settings may cause interference.)
The default router wifi setting:
The optimize setting:
sonnyyu:
You don't need to have an Android device to do this, with a Windows (Vista, 7, 8.x) you can do the same with Vistumbler
(Vistumbler - Open Source WiFi scanner and channel scanner for windows) :wink:
hth,
Ralf
AlexDC what's the brand/model of your router? What are its wifi settings? (channel, frequency, whatever...)
Hi Frederico,
My router is a french model provided by my ISP : a "SFR Box".
But I changed my channel as suggested and it seems working.
Thanks everybody for your help !
Finally, it doesn't work... :frowning:
If i found a solution, I will keep you informed...
