Wifi
I am trying to use the client.connect method to connect to external website with my Wifi Shield. I get an IP address and I am connected to the wireless network, but the client.connect command always returns false. When I run the following code I get the following in the serial monitor:
Attempting to connect to SSID: xxxxxxxxxxxxxxxxxxxxxxxxxx
IP Address: 192.168.0.177
signal strength (RSSI):-38 dBm
Firmware version: 1.1.0
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
Any help would be appreciated.
#include <SPI.h>
#include <WiFi.h>
// the IP address for the shield:
IPAddress ip(192, 168, 0, 177);
//Serial.begin(9600);
char ssid[] = "xxxxxxxxxxxxxxxxxxxxxxxx";    // your network SSID (name)
char pass[] = "xxxxxxxxxxxxxxxxxxxx"; // your network password (use for WPA, or use as key for WEP)
char server[] = "www.arduino.cc";
//IPAddress server(64,131,82,241);
unsigned long lastConnectionTime = 0;            // last time you connected to the server, in milliseconds
const unsigned long postingInterval = 10L * 1000L; // delay between updates, in milliseconds
int status = WL_IDLE_STATUS;
// Initialize the Ethernet client library
WiFiClient client;
 // Initialize serial and wait for port to open:
 while (!Serial) {
   ; // wait for serial port to connect. Needed for Leonardo only
 // check for the presence of the shield:
 if (WiFi.status() == WL_NO_SHIELD) {
   Serial.println("WiFi shield not present");
   while(true);  // don't continue
 WiFi.config(ip);
 // attempt to connect to Wifi network:
 while ( status != WL_CONNECTED) {
   Serial.print("Attempting to connect to SSID: ");
   Serial.println(ssid);
   // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
   status = WiFi.begin(ssid, pass);
   WiFi.config(ip);
   // wait 1 seconds for connection:
   delay(10000);
 printWifiStatus();
 // print your WiFi shield's IP address:
 Serial.print("IP Address: ");
 Serial.print("Firmware version: ");
 Serial.println(WiFi.firmwareVersion());
   quit();
  * Code commented out
 Serial.println("\nStarting connection to server...");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.println("connected to server");
    // Make a HTTP request:
    client.println("GET /search?q=arduino HTTP/1.1");
    client.println("Host: www.google.com");
    client.println("Connection: close");
    client.println();
  else {
    Serial.println("FAIL");  // <--- always fails!!!!!!!!!!
    quit();
 // if there's incoming data from the net connection.
 // send it out the serial port.  This is for debugging
 // purposes only:
 while (client.available()) {
   char c = client.read();
   Serial.write(c);
 // if ten seconds have passed since your last connection,
 // then connect again and send data:
 if (millis() - lastConnectionTime > postingInterval)
   httpRequest();
// this method makes a HTTP connection to the server:
void httpRequest()
 // close any connection before send a new request.
 // This will free the socket on the WiFi shield
 client.stop();
 // if there's a successful connection:
   Serial.println("connecting...");
   // send the HTTP PUT request:
   client.println("GET /latest.txt HTTP/1.1");
   client.println("Host: www.arduino.cc");
   client.println("User-Agent: ArduinoWiFi/1.1");
   client.println();
   // note the time that the connection was made:
   lastConnectionTime = millis();
   // if you couldn't make a connection:
   Serial.println("connection failed");
void printWifiStatus()
 // print the SSID of the network you're attached to:
 Serial.print("SSID: ");
 Serial.println(WiFi.SSID());
 IPAddress ip = WiFi.localIP();
 Serial.println(ip);
 // print the received signal strength:
 long rssi = WiFi.RSSI();
 Serial.print("signal strength (RSSI):");
 Serial.print(rssi);
 Serial.println(" dBm");
void quit()
while(true);
Is there anything in your network that provides domain resolution? How does the Arduino know what IP address (the only way it knows to navigate) to connect to when you provide a server name?
