Hello,
I'll try to make a GET request inside the loop() method with the WiFiClient.
Unfortunatly I never get the response from the server. The request seems ok because the connection to the server is ok.
I noticed in all the sketch exemple, the request was made inside the setup() method and the read of the response is made inside the loop() method. Why ?
Here is an exemple :
#include <SPI.h>
#include <WiFi101.h>
char ssid[] = "";
char pass[] = "";
int status = WL_IDLE_STATUS;
char server[] = "api.timezonedb.com";
WiFiClient client;
while (!Serial) {
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
while (true);
// attempt to connect to WiFi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
WiFi.end();
status = WiFi.begin(ssid, pass);
delay(5000);
Serial.println("Connected to wifi");
printWiFiStatus();
Serial.println("\nStarting connection to server...");
if (client.connect("google.com", 80)) {
Serial.println("connected to server");
// Make a HTTP request:
client.println("GET /search?q=test HTTP/1.1");
client.println("Host: google.com");
client.println("Connection: close");
client.println();
Serial.println("Can't connect to server");
Serial.println("Wait response");
delay(2000);
while (client.available()) {
char c = client.read();
Serial.write(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting from server.");
client.stop();
while (true);
delay(2000);
In this example :
- The connection to the wifi AP is ok
- The connection to server (google.com) is ok
- I never had a response
Here is my env :
- MacOS
- Arduino IDE 1.8.10
- Wifi101 library 0.16.0
- Wifi firmware 19.6.1
- MKR1000 Model B
I have the same problem on my 2 MKR1000.
Does anyone have any clue ?
Thanks.
