WiFiClient.available() hangs
My Arduino hangs. By putting some Serial.print between the code, I believe it hangs at WiFiClient.available(). Here is the relevant code:
void checkOK() {
  Serial.println("Checking available");
  if (client.available()) {
    Serial.println("reading");
    uint8_t simplifiedReply = client.read();
    Serial.println("read");
    if (simplifiedReply == 1) {
      allowSend = true;
      Serial.println("flag send");
  Serial.println("Checking available complete");
client is initialized as WiFiClient client;
checkOK() is called in the loop if allowSend is false.
The server send reply at ~35ms interval
The Serial log:
Checking available
Checking available
Checking available
reading
read
flag send
Checking available
Checking available
Checking available
Checking available
Checking available
Checking available
After running smoothly for several minutes (non-deterministic), it stuck after printing "Checking available", so I believe it hangs in client.available().
I am running on Arduino Nano 33 IOT. Any comments would be much appreciated.
Edit 1:
I removed the available check which looks redundant. But I still have the same problem, now it stuck at client.read().
void checkOK() {
  Serial.println("reading reply");
  Serial.println(simplifiedReply);
    allowSend = true;
Log:
255
reading reply
255
reading reply
255
reading reply
255
reading reply
255
reading reply
255
reading reply
client.read() gives 255(-1) if there is nothing to read. It stuck at reading again. I think either I damaged client data or there is a bug within WiFiClient code.
Edit 2:
I changed the reply interval from ~35ms to ~100ms, now it runs for 1 hour non-stop without a problem. However, sometimes the read function still hangs for short period of time, sometimes as long as 6 seconds. Now, I am more inclined to believe it is a hardware problem.
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Thank you for the advice. I am posting the full sketch code following Edit2 here:
#include <WiFiNINA.h>
#include "wpa_cred.h"
#include "device_descriptor.h"
int status = WL_IDLE_STATUS;             // the Wi-Fi radio's status
int ledState = LOW;                       //ledState used to set the LED
unsigned long previousMicrosInfo = 0;     //will store last time Wi-Fi information was updated
unsigned long previousMicrosReport = 0;
const unsigned long reportInterval = 100000;            // interval at which to update the board information
const unsigned long collectInterval = 1000;            // interval at which to collect analog signal
byte buffer[4000]; // micros (4 bytes) + uint16_t (2 bytes) * 3 = 10 bytes per frame
uint16_t bufferPointer = 4; // four bytes are for total byte counts
uint16_t maxbuffer = 2004; // 4 + 10 * 200 = 1004, that's 200 frames
bool allowSend = true;
IPAddress server(192, 168, 137, 1);
WiFiClient client;
uint32_t reverseWordEndianness(uint32_t src) { // use -O3 will get rid of the call stack
  uint32_t dest = 0;
  asm ("REV %0, %1"
    : "=r" (dest)
    : "r" (src));
  return dest;
void connectToWifi() {
  // attempt to connect to Wi-Fi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to network: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  // you're connected now, so print out the data:
  Serial.println("You're connected to the network");
  Serial.println("---------------------------------------");
void sendDeviceDescriptor() {
  uint32_t dataLength = strlen(descriptor);
  uint32_t dataLengthBE = reverseWordEndianness(dataLength);
  client.write(reinterpret_cast<byte*>(&dataLengthBE), 4);
  size_t writtenLen = client.write(descriptor, dataLength); // assume utf-8 works
  allowSend = false;
  Serial.print("descriptor bytes sent: ");
  Serial.println(writtenLen);
void connectToPainlabControlPanel() {
  while (1) {
    if (client.connect(server, 8124)) {
      // connect to pain lab control panel
      Serial.println("Connected to control panel");
    Serial.println("Can't connect to pain lab control panel");
    delay(10000);
  Serial.println("Sending descriptor");
  sendDeviceDescriptor();
  analogReadResolution(16); // padded to fit uint16_t
  //Initialize serial and wait for port to open:
  // while (!Serial);
  // set the LED as output
  pinMode(LED_BUILTIN, OUTPUT);
  connectToWifi();
  connectToPainlabControlPanel();
  Serial.println("setup completed");
void printNetworkInfo() {
  Serial.println("Board Information:");
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print your network's SSID:
  Serial.println("Network Information:");
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.println(rssi);
#define COPY_AND_ADVANCE(data) \
    memcpy(buffer + bufferPointer, reinterpret_cast<byte*>(&data), sizeof(data));   \
    bufferPointer += sizeof(data);\
void readAndPushFrameIntoBuffer() {
  if (bufferPointer > maxbuffer) {
    Serial.print("Frame dropped, allowSend: ");
    Serial.println(allowSend);
    bufferPointer = 4;
  unsigned long ts = micros();
  // Remember to change ADC clock to at least DIV64
  uint16_t a0_reading = analogRead(A0); // GSR
  uint16_t a2_reading = analogRead(A2); // Heart Rate
  uint16_t a4_reading = analogRead(A4); // Myoware muscle sensor
  COPY_AND_ADVANCE(ts);
  COPY_AND_ADVANCE(a0_reading);
  COPY_AND_ADVANCE(a2_reading);
  COPY_AND_ADVANCE(a4_reading);
void checkOK() {
  //Serial.println("reading reply");
  //Serial.println(simplifiedReply);
    allowSend = true;
 if (!allowSend) {
    checkOK();
 unsigned long currentMicrosInfo = micros();
 // check if the time after the last update is bigger the interval
 if (currentMicrosInfo - previousMicrosInfo >= collectInterval) {
   previousMicrosInfo = currentMicrosInfo;
   readAndPushFrameIntoBuffer();
 //Serial.println(currentMicrosInfo - previousMicrosReport);
 if (allowSend && bufferPointer > 4) {
    if (currentMicrosInfo - previousMicrosReport >= reportInterval) {
      previousMicrosReport = currentMicrosInfo;
      *(reinterpret_cast<uint32_t*>(buffer)) = reverseWordEndianness(bufferPointer - 4); // write four BE bytes to buffer header
      client.write(buffer, bufferPointer); // ~3.5ms
      bufferPointer = 4;
      allowSend = false;
      // if the LED is off turn it on and vice-versa:
      if (ledState == LOW) {
        ledState = HIGH;
        ledState = LOW;
      // set the LED with the ledState of the variable:
      digitalWrite(LED_BUILTIN, ledState);
Basically, it is a program that reads from analog pins every 1ms (collectInterval) and pack them into batch frames (with 4 big endian leading bytes specifiying the size), write to the server every 100ms ( reportInterval), and receive one byte acknowledgement response from the server to allow to send another batch frames. In Edit2, I changed reportInterval from 30ms to 100ms (also increase maxBuffer), then it won't hang (still hangs for several seconds from time to time, so I am considering changing boards or using serial communication).
Note to keep three analog read complete within 1ms, I have changed ADC_CTRLB_PRESCALER_DIV512 to ADC_CTRLB_PRESCALER_DIV64 mannually.
I will try to make a replicable version using simple server script and minimised intense read / write arduino sketch. But if anyone knows there is a limit in the hardware, then I don't need to do this...
