Example of sending GPS RMC over UDP
GPS Portal, part of Tardis Time Server by: M. Ray Burnette 20150915
Create a private 10. network and capture all DNS requests to the Time Portal
Respond to UDP and DHCP and DNS
Arduino GUI 1.6.7 on Linux Mint 17.3 on 20160206
ESP8266 core: http://arduino.esp8266.com/staging/package_esp8266com_index.json
Sketch uses 235,297 bytes (54%) of program storage space. Maximum is 434,160 bytes.
Global variables use 32,153 bytes (39%) of dynamic memory, leaving 49,767 bytes for local variables.
#define LEDpin 2 // ESP82660-1 8-pin module LED is on GPIO-02
#include <Streaming.h> // \Documents\Arduino\libraries\Streaming (legacy) user-installed
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#include <DNSServer.h>
#include "./Utility.h" // See Notes tab for credits
const byte DNS_PORT = 53; // Listen DNS requests on port 53
int ack_Count = 0;
uint8_t hour, minute, seconds; // hour, minure, seconds,
uint8_t day, month, year; // year, month, day;
unsigned int localPort = 8888; // any unused port on LAN
IPAddress apIP(10, 10, 10, 1); // Private network address: local & gateway
IPAddress broadcastIP(255, 255, 255, 255); // https://en.wikipedia.org/wiki/Multicast
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; // buffer to hold incoming packet,
char ReplyBuffer[] = "????????????"; // a 12 character string to send back
DNSServer dnsServer; // Create the DNS object
WiFiUDP UDP; // UDP protocol on STA interface, localPort
extern "C" {
#include "user_interface.h" // used for diagnostic ESP.getFreeHeap()
// Forward declarations
void GPSstuff(char c);
Serial.begin(4800); // Initialise Serial for older PMB-648
Serial << (F("2015 Ray Burnette")) << endl;
Serial << (F("Tardis Time Portal Version 0.20150915")) << endl;
WiFi.mode(WIFI_AP_STA); // AP + STA
WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0)); // subnet FF FF FF 00
WiFi.softAP("TardisTime");
dnsServer.start(DNS_PORT, "*", apIP); // "*" creates a captive portal
while (! UDP.begin(localPort) ) { // UDP protocol connected to localPort which is a variable
Serial << "+" ;
yield(); // Play nicely with RTOS (alias = delay(0))
} // This will loop forever if UDP fails
Serial << endl;
Serial << (F("Setting pin#2 to Output mode")) << endl;
pinMode(2, OUTPUT); // initialise pin mode
dnsServer.processNextRequest(); // TCP Address handler when requested
yield(); // yield for RTOS
// Listener(); // UPD (can you hear me now?)
// yield();
if (Serial.available() > 0) { // anything in the serial hw buffer?
char c = Serial.read(); // if so, fetch the next character from FIFO
GPSstuff(c);
yield();
} // loop repeats forever unless stack crashes or uC hangs
void GPSstuff(char c) { // GPSbuffer[]
static int i, j; // persistent within function scope
static char q;
static bool flag = false;
static char GPSbuffer[120]; // GPS serial line input buffer
q = c;
if ( q == 0x24 ) // '$'
i = 0; // brute force sync on '$' to GPSbuffer[0]
// Serial << "Found $" << endl;
if ( i < 120) GPSbuffer[i++] = q;
if (q == 0x0d) {
flag = true; // is the character a CR for eol
i = 0;
if (flag) { // test for end of line and if the right GPSbuffer
flag = false; // reset for next time
digitalWrite(LEDpin, !(digitalRead(LEDpin))); // blink LED (Warning: using ESP8266-01 module)
UDP.beginPacketMulticast(broadcastIP, localPort, apIP);
// Serial << "We are in the flag routine..." << GPSbuffer[3] << GPSbuffer[4] << GPSbuffer[5] << endl;
// Serial << "Analyzing " << GPSbuffer[3] << GPSbuffer[4] << GPSbuffer[5] << endl;
if ( (GPSbuffer[3] == 0x52) && (GPSbuffer[4] == 0x4d) && (GPSbuffer[5] == 0x43)) // 'R' && 'M' && 'C'
long int RAM = ESP.getFreeHeap();
Serial << "Free= " << RAM << endl;
for (j = 0; j < 120 ; j++) {
UDP.write(GPSbuffer[j]);
UDP.write("\r\n"); // terminate the line
UDP.endPacket(); // clear UDP buffer
Serial << GPSbuffer << endl;
void Listener() {
int packetSize = UDP.parsePacket(); // if there’s data available, read a packet
if (packetSize)
Serial << endl;
Serial << (F("Received packet of size: "));
Serial << (packetSize);
Serial << (F(" From remote: "));
IPAddress remote = UDP.remoteIP();
for (int k = 0; k < 4; k++)
Serial << (remote[k], DEC);
if (k < 3)
Serial << (F("."));
Serial << (F(", port: "));
Serial << " UDPremotePort: " << (UDP.remotePort()) << endl ;
UDP.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE); // read the packet into packetBufffer
Serial << (F("Contents: "));
int value = packetBuffer[0] * 256 + packetBuffer[1];
Serial << value << endl;
Serial << (F("Ack counter: "));
Serial << (ack_Count) << endl; // ever increasing serialnumber
intToStr(ack_Count, ReplyBuffer, 12); // 12 characters wide
UDP.beginPacket(UDP.remoteIP(), UDP.remotePort()); // send a reply, to the IP address and port that sent us the packet we received
UDP.write(ReplyBuffer);
UDP.endPacket();
++ack_Count;
} // if(packetSize)
Utility.cpp (1.9 KB)
Utility.h (283 Bytes)
