This is the loop from the server example that services http requests:
// listen for incoming clients
WiFiEspClient client = server.available();
if (client)
Serial.println("New client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected())
if (client.available())
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank)
Serial.println("Sending response");
// end a standard http response header
// use \r\n instead of many println statements to speedup data send
client.print("HTTP/1.1 200 OK\r\nContent-Type: text/html\r\nConnection: close\r\n" // the connection will be closed after completion of the response
"Refresh: 20\r\n" // refresh the page automatically every 20 sec
"\r\n");
client.print("<!DOCTYPE HTML>\r\n");
client.print("<html>\r\n");
client.print("<h1>Hello World!</h1>\r\n");
client.print("Requests received: ");
client.print(++reqCount);
client.print("
\r\n");
client.print("Analog input A0: ");
client.print(analogRead(0));
client.print("
\r\n");
client.print("</html>\r\n");
if (c == '\n')
// you're starting a new line
else if (c != '\r')
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(10);
// close the connection:
client.stop();
Serial.println("Client disconnected");
I don't understand why it won't work if I separate the read and print parts of the loop something like this:
if (client)
String strReq;
strReq += (String(c));
if (c == '\n')
else if (c != '\r')
if (client.connected())
if (strReq == "GET / HTTP/1.1")
"\r\n");
client.print("
\r\n");
client.print("
\r\n");
else if (strReq == "something else")
delay(10);
client.stop();
How is the 'client' interacting with that while loop such that my preferred code, just above, won't work, i.e. the web browser just sits there waiting forever for the arduino client to send the http data.
