Hi all!
I’m using an ESP8266 and Arduino Zero with the WiFiEsp library.
Don’t understand how WiFi.status() works.
It should return an int as indicated at : Arduino - WiFiStatus
I tried to force a “WL_CONNECT_FAILED” putting a wrong password for my home network, but the return
is always “WL_IDLE_STATUS” which is number 3.
I think I’m missing something…
Help is appreciated
Thank you
WiFiEsp example: ConnectWPA
This example connects to an encrypted WiFi network using an ESP8266 module.
Then it prints the MAC address of the WiFi shield, the IP address obtained
and other network details.
For more details see: http://yaab-arduino.blogspot.com/p/wifiesp-example-connect.html
#include "WiFiEsp.h"
char ssid[] = "SSID"; // your network SSID (name)
char pass[] = "password"; // your network password
int status = WL_IDLE_STATUS; // the Wifi radio's status
int i = 0;
// initialize serial for debugging
while(!SerialUSB){;}
// initialize serial for ESP module
Serial1.begin(115200);
// initialize ESP module
WiFi.init(&Serial1);
status = WiFi.status();
Serial.print("WIFISTATUS.:");
Serial.println(WiFi.status());
Serial.print("I.:");
Serial.println(i);
while((status != WL_CONNECTED) && (i<5))
WiFi.begin(ssid, pass);
i++;
Serial.println("Trying to Reconnect to WiFi Network ");
delay(5000);
//Serial.println(status);
// printCurrentNet();
// printWifiData();
delay(5000);
void printWifiData()
// print your WiFi shield's IP address
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print your MAC address
byte mac[6];
WiFi.macAddress(mac);
char buf[20];
sprintf(buf, "%02X:%02X:%02X:%02X:%02X:%02X", mac[5], mac[4], mac[3], mac[2], mac[1], mac[0]);
Serial.print("MAC address: ");
Serial.println(buf);
void printCurrentNet()
// print the SSID of the network you're attached to
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print the MAC address of the router you're attached to
byte bssid[6];
WiFi.BSSID(bssid);
char buf[20];
sprintf(buf, "%02X:%02X:%02X:%02X:%02X:%02X", bssid[5], bssid[4], bssid[3], bssid[2], bssid[1], bssid[0]);
Serial.print("BSSID: ");
// print the received signal strength
long rssi = WiFi.RSSI();
Serial.print("Signal strength (RSSI): ");
Serial.println(rssi);
Serial.print("WiFi Status.:");
