WiFiManager.autoConnect garbled code problem
#include <WiFiManager.h>
  WiFiManager wifiManager;
  wifiManager.setDebugOutput(true);
  wifiManager.autoConnect("AutoConnectAP","12345678");
  Serial.println("ABCDEFGHIJKLMNOPQRSTUVWXYZ");
  • Serial port output content:
    18:39:40.970 -> ABCDEFGHIJKLMNOPQRSTUVWXYZ
    18:39:40.970 -> ABCDEFGHIJLMNOPQRSTUVWXYZ
Does the same loop() code print correctly if you comment out the WiFi stuff like this?
// #include <WiFiManager.h>
  // WiFiManager wifiManager;
  // wifiManager.setDebugOutput(true);
  // wifiManager.autoConnect("AutoConnectAP","12345678");
Either way, you could try adding a delay() like this:
  delay(100);
  Serial.begin(115200);  // 设置串口通信波特率为 9600
  WiFi.mode(WIFI_STA);
  wifiManager.setDebugOutput(false);
//  wifiManager.autoConnect("AutoConnectAP","12345678");  //创建一个模拟wifi,使用密码登录
/*每隔5秒输出一次内存信息*/
If I write it like this, there is no problem and the content can be output normally, but I can't comment it because it is used to configure the network. I don't understand how to avoid this error.
Adding a small delay will slow down the loop and may prevent truncation due to overwhelming the serial buffer. For example:
  delay(500);  // Add a delay to stabilize the Serial output
I tried several methods, but none of them could solve my problem.
  delay(100);  // Add a delay to stabilize the Serial output
  Serial.flush();
  • The problem is that this line of code wifiManager.autoConnect("AutoConnectAP","12345678");
    It outputs garbled characters, and I haven't found a solution yet
Do you mean that some of the characters A to Z are missing, and there are no additional unpexpected characters? I.E. as shown in post #1.
There's a big difference between just missing characters and seeing extra unexpected characters. If it's just missing characters then something isn't giving the Serial code enough time to transmit all the characters.
Serial.println() returns the number of characters printed. You could check its return value to see if the characters are not being accepted for transmission because the transmit buffer is full.
As a matter of curiosity, what hardware are you using here?
  • This is my test data. It doesn't seem like the buffer is full because there are still 100 left, but the output is garbled or missing characters.
I don't have any more suggestions at the moment. If I think of something I'll post it.
  int serialAvailableForWrite = Serial.availableForWrite(); //可用缓冲区字节
  uint32_t freeHeap = ESP.getFreeHeap(); //可用内存
  if (serialAvailableForWrite < 50) {  // 如果缓冲区空间小于10字节
    while (Serial.available() > 0) {
      Serial.read();
  }else{
    Serial.print("H: ");Serial.print(serialAvailableForWrite);Serial.print(" - ABCDEFGHIJKLMNOPQRSTUVWXYZ");Serial.print(" - memory: ");Serial.println(freeHeap);
Write like this
