I have tested this code on Lolin Nodemcu v3 and it is working perfectly. However when I switched to ESP-01 The Wifimanager works but no custom parameters are saved although WIFI Credentials are.
#include <FS.h> // this needs to be first, or it all crashes and burns...
#include <WiFiManager.h> // https://github.com/tzapu/WiFiManager
#include <ArduinoJson.h> // https://github.com/bblanchon/ArduinoJson
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <DNSServer.h>
int ledPin = 2;
char mqtt_username[40]; char mqtt_password[40]; String mqttusername; String mqttpassword;
WiFiManager wm;
bool shouldSaveConfig = false;
void saveConfigCallback () { Serial.println("Should save config"); shouldSaveConfig = true; }
Serial.begin(115200); pinMode(ledPin, OUTPUT); digitalWrite(ledPin, LOW);
setupSpiffs(); wm.setSaveConfigCallback(saveConfigCallback);
WiFiManagerParameter custom_mqtt_username("username", "username", mqtt_username, 40);
WiFiManagerParameter custom_mqtt_password("password", "password", mqtt_password, 40);
wm.addParameter(&custom_mqtt_username); wm.addParameter(&custom_mqtt_password);
strcpy(mqtt_username, custom_mqtt_username.getValue()); mqttusername = custom_mqtt_username.getValue();
strcpy(mqtt_password, custom_mqtt_password.getValue()); mqttpassword = custom_mqtt_password.getValue();
if (shouldSaveConfig) { Serial.println("saving config"); DynamicJsonDocument doc(1024);
doc["mqtt_username"] = mqtt_username; doc["mqtt_password"] = mqtt_password;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) { Serial.println("failed to open config file for writing"); }
serializeJson(doc, Serial); serializeJson(doc, configFile); configFile.close(); Serial.println(""); //end save
while (WiFi.status() != WL_CONNECTED) { delay(100); Serial.print("."); resetbtn(); } Serial.println("");
Serial.print("Connected to WiFi: "); Serial.println(WiFi.SSID());
Serial.print("IP: "); Serial.println(WiFi.localIP());
Serial.println("connected...yeey :)");
Serial.println("user is: "); Serial.println(mqtt_username);
Serial.println("pass is: "); Serial.println(mqtt_password);
void setupSpiffs(){
// SPIFFS.format();
Serial.println("mounting FS...");
if (SPIFFS.begin()) { Serial.println("** Mounting file system **");
if (SPIFFS.exists("/config.json")) { Serial.println("** Reading config file **"); File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
size_t size = configFile.size(); std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size); DynamicJsonDocument doc(1024); DeserializationError error = deserializeJson(doc, buf.get());
if (error) { Serial.print(F("deserializeJson() failed: ")); Serial.println(error.c_str()); return; }
strcpy(mqtt_username, doc["mqtt_username"]); strcpy(mqtt_password, doc["mqtt_password"]);
} else { Serial.println("** Failed to load json config **"); }
configFile.close(); Serial.println("** Closed file **");
} else { Serial.println("** Failed to mount FS **"); }
void resetbtn() { if ( digitalRead(ledPin) == HIGH ) { wm.startConfigPortal("Burooq"); Serial.println("connected...yeey :)"); } }
At the serial Monitor I get:
*WM: [2] <- HTTP WiFi save
*WM: [3] Method: POST
*WM: [2] Parameters
*WM: [2] --------------------
*WM: [2] username: test
*WM: [2] password: test
*WM: [3] Sent wifi save page
*WM: [2] processing save
*WM: [2] Connecting as wifi client...
*WM: [3] STA static IP:
*WM: [2] setSTAConfig static ip not set, skipping
*WM: [1] CONNECTED:
*WM: [1] Connecting to NEW AP: MYSSID
*WM: [3] Using Password: SSIDPASS
*WM: [3] WiFi station enable
*WM: [3] enableSTA PERSISTENT ON
*WM: [1] connectTimeout not set, ESP waitForConnectResult...
*WM: [2] Connection result: WL_CONNECTED
*WM: [3] lastconxresult: WL_CONNECTED
*WM: [1] Connect to new AP [SUCCESS]
*WM: [1] Got IP Address:
*WM: [1] XXX.XXX.XXX.XXX
Should save config
*WM: [2] disconnect configportal
*WM: [2] restoring usermode STA
*WM: [2] wifi status: WL_CONNECTED
*WM: [2] wifi mode: STA
*WM: [1] config portal exiting
connected...yeey :)
Connected to WiFi: MYSSID
IP: XXX.XXX.XXX.XXX
connected...yeey :)
user is:
pass is:
user is:
pass is:
user is:
pass is:
