I tried to install this library inside the Arduino IDE - but when trying to also install the required dependencies, I get a 'no protocol' error.
Therefore I went for the installation without its dependencies - not knowing if something is missing or not.
Does anybody know what dependencies are necessary when this WiFiManager_Generic_Lite library is installed for intended usage on the Adafruit Feather M0 Board ?
And second question:
Under the File->Example Menu I find more than 10 examples - but which one to pick for the Adafruit Feather M0 Board ? (see screenshot for the choices):
Can somebody please give me step-by-step instructions on how to use this WiFiManager_Generic_Lite library - especially for usage on the Adafruit Feather M0 Board ?
My intended use-case is to have the WiFiManager_Generic_Lite create an Access-Point at first and then the user can enter his or her credentials (i.e. SSID and PW) and eventually the WiFiManager_Generic_Lite would switch to a WebServer mode (keeping the credeentials in Flash). I know that WiFiManager_Generic_Lite can do so - but I just fail miserably in finding the right configuration and library installs.
Finally, using the Adafruit Feather M0, you must take care of the differnt pinout :
Please set the pins as follows - and by doing so your Access Point using the WiFiManager_Generic_Lite library will finally work.
// This is the only line of code that is Feather M0 WINC1500
// specific, the rest is the same as for the WiFi101
WiFi.setPins(8, 7, 4, 2);
// ... the rest of whatever was there...
In addition, there is an issue with the Serial Monitor: It turned out that the WiFiManager_Generic_Lite library for some reason requires the Serial Monitor to be ON. With the following timeout set in SAMD_WiFi.ino (line 80), you can circumwent this issue:
Replace: while (!Serial); by while (!Serial && (millis() < 3000));
Now having done the above changes (i.e. pinout and SerialMonitor-timeout), the SAMD_WiFi code compiles and downloads correctly to my Adafruit Feather M0 Board.
However, there is one last issue that I don't know how to solve:
If I connect to this Access Point with a mobile Phone (iOS or Android) or also with my Mac, I do not get the settings HTML page if I go to the browser and type http://192.168.4.1 as stated on the WiFiManager_Generic_Lite manual.
What could be the reason why no settings page crops up with a working Access Point in place ??
I would really be able to make the WiFiManager_Generic_Lite library work with my Adafruit Feather M0. Any ideas ??
