Continued from
Changelog
Release v1.7.1
- Optimize code
Release v1.7.0
- Use WiFiMulti_Generic library to connect to the best of multi-WiFi APs, with auto-checking / auto-reconnecting features when WiFi connection is lost.
- Update
Packages' Patches
Release v1.6.0
- Optimize code by passing by
reference
instead ofvalue
- Optional
Board_Name
in Config Portal. Check option to remove board name from web page #25 - Add optional
CONFIG_MODE_LED
to beON
when in Config Portal mode. Check Knowing when configuration mode is on or off #26 - Add function
isConfigMode()
to signal system is in Config Portal mode. - Update
Packages' Patches
Release v1.5.1
- Update to be compatible with new
FlashStorage_SAMD
- Use better
FlashStorage_STM32
orFlashStorage_STM32F1
library for STM32 - Add support to generic SAMD21 boards :
__SAMD21E1xA__
,__SAMD21G1xA__
and__SAMD21J1xA__
- Update
Packages' Patches
Major Release v1.5.0
- Add support to RP2040-based boards, such as NANO_RP2040_CONNECT, using Earle Philhower's arduino-pico core
- Fix the blocking issue in loop(). Check retries block the main loop #18
- Configurable
WIFI_RECON_INTERVAL
. Check retries block the main loop #18 - Update
Packages' Patches
Release v1.4.1
- Update
platform.ini
andlibrary.json
to use originalkhoih-prog
instead ofkhoih.prog
after PIO fix - Update
Packages' Patches
Major Release v1.4.0
- Add support to RP2040-based boards, such as RASPBERRY_PI_PICO, ADAFRUIT_FEATHER_RP2040 and GENERIC_RP2040, using Earle Philhower's arduino-pico core.
- Add support to RP2040-based boards, such as Nano_RP2040_Connect, RASPBERRY_PI_PICO, ADAFRUIT_FEATHER_RP2040 and GENERIC_RP2040, using Arduino-mbed RP2040 core.
- Update
Packages' Patches
- Add
LibraryPatches
for Adafruit_MQTT_Library to fix compiler error for RP2040-based and many other boards.
Major Release v1.3.0
- Enable scan of WiFi networks for selection in Configuration Portal. Check PR for v1.3.0 - Enable scan of WiFi networks #10. Now you can select optional SCAN_WIFI_NETWORKS, MANUAL_SSID_INPUT_ALLOWED to be able to manually input SSID, not only from a scanned SSID lists and MAX_SSID_IN_LIST (from 2-6 for ESP8266-AT or 2-15 for other)
- Minor enhancement to not display garbage when data is invalid
- Tested with new Arduino Core for STM32 v2.0.0 and add support to new STM32L5 boards.
Release v1.2.0
- Permit optionally inputting one set of WiFi SSID/PWD by using
REQUIRE_ONE_SET_SSID_PW == true
- Enforce WiFi Password minimum length of 8 chars
- Enhance MultiWiFi connection logic
Release v1.1.3
- Fix invalid "blank" or NULL Config Data treated as Valid. Check WiFiManager connection attempt to unconfigured ("blank") SSID after restart on SAMD #8
- Fix compiler warnings.
Release v1.1.2
- Fix MultiWiFi connection bug. Check SAMD MultiWiFi issues when first WiFi SSID configured in CP is invalid or not available #6
- Bump up to version v1.1.2 to sync with WiFiManager_NINA_Lite
