WiFimanager how to know when exiting "Portal"?
Hi!
When entering "Configuration Portal" it's easy to execute code where you find "Serial.println("Configportal running");" here below.
But is there any way to get notice of when leaving the portal? Like a bool set to true when exiting.
Or maybe even more info like status when saving settings or something other useful?
// Example file from: https://github.com/tzapu/WiFiManager/blob/master/examples/NonBlocking/AutoConnectNonBlocking/AutoConnectNonBlocking.ino
#include <WiFiManager.h> // https://github.com/tzapu/WiFiManager
WiFiManager wm;
    WiFi.mode(WIFI_STA); // explicitly set mode, esp defaults to STA+AP
    //reset settings - wipe credentials for testing
    //wm.resetSettings();
    wm.setConfigPortalBlocking(false);
    wm.setConfigPortalTimeout(60);
    //automatically connect using saved credentials if they exist
    //If connection fails it starts an access point with the specified name
    if(wm.autoConnect("AutoConnectAP")){
        Serial.println("connected...yeey :)");
    else {
    wm.process();
https://github.com/tzapu/WiFiManager#save-settings
I could not make it work the non blocking way, but I don't remember why
