Hi guys, what's up?
I'm trying to use the wifimanager in my project, but first i want to do some tests.
I already have download the lybraries: GitHub - bblanchon/ArduinoJson: 📟 JSON library for Arduino and embedded C++. Simple and efficient. and GitHub - tzapu/WiFiManager: ESP8266 WiFi Connection manager with web captive portal
when i use the example AutoConnect nothing happens, it isn't show te AutoConnect AP for i use to configure the wifi.
The example code is:
#include <ESP8266WiFi.h>Â Â Â Â Â //https://github.com/esp8266/Arduino
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>Â Â Â Â Â //https://github.com/tzapu/WiFiManager
  //WiFiManager
  //Local intialization. Once its business is done, there is no need to keep it around
  WiFiManager wifiManager;
  //reset saved settings
  //wifiManager.resetSettings();
 Â
  //set custom ip for portal
  //wifiManager.setAPStaticIPConfig(IPAddress(10,0,1,1), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
  //fetches ssid and pass from eeprom and tries to connect
  //if it does not connect it starts an access point with the specified name
  //here "AutoConnectAP"
  //and goes into a blocking loop awaiting configuration
  wifiManager.autoConnect("AutoConnectAP");
  //or use this for auto generated name ESP + ChipID
  //wifiManager.autoConnect();
 Â
  //if you get here you have connected to the WiFi
  Serial.println("connected...yeey :)");
 Â
